79 390 OR suspension
Discussion in 'Vintage Restoration Projects' started by Ben Stevens, Jun 21, 2015.
  1. Ben Stevens Husqvarna
    none yet
    Ok, I'm new to this forum and vintages Huskys as well. I have a 79 390 OR and am looking to set it up for the Calvmx series. I now have Curnutts on the rear (tired of getting almost thrown over the bars when I come up short on doubles) and have picked up a pair of Ohlins 16.5" remote resivoirs that need serious work. Any recommendations on who to have do the work ( I live in So. Cal but not opposed to shipping ). I also have a 40 mm fork setup for it ( now has the 35mm), I have 2 pairs , one has white lowers and the other the silver lowers. The silver lowers are about 3/4" shorter then the white, not sure which pair to rebuild ? Any advice would be greatly appreciated. It's a fun track bike , just not forgiving of rider error.
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    welcome to the forum, and you are certainly in the right place. the parts you are thinking of using will be a huge upgrade. there are many who can rework your ohlins, the only place i can personally recommend is WER but they specialize in enduro/woods uses. great service and knowlegde tho.
    as for the forks, i would use the ones have the better height application for your chassis. the shorter ones are likely from a wr model. whoever does your shocks can set you up with a good spring rate for the rear as well as the front. after you get your suspension dialed in, it will unlock the great chassis that is a hoosky!
    im sure someone will be along with some suggestions for you that are more helpful for moto-x application. not sure if you have ever had your suspension set up professionally but its such a huge difference getting the springs and damping sorted, good luck.
    dont be afraid to post some pics as well.
  3. Chayzed Pilot Husqvarna
    So Cal
    2004 TC450,1978 390CR,1983 430 Wr
    A gaggle of them
    Send the Ohlins to Drew @ WER, you can't go wrong.
    justintendo likes this.
  4. rwgregory Husqvarna
    Chula Vista, CA
    1985 500XC, 1987 510TX, 1990 510WMX
    1979 Honda CR250,'88 CR500,'92 XR600
    I have heard nothing but good things about Drew @ WER, but he is on the east coast. You may want to give Brian at Moto-Vintage Suspension a call. He is in San Diego, CA and does suspension work for a lot of the CALVMX riders. He is an Ohlins dealer and does quality work at fair prices. I have had him go thru a couple of Ohlins shocks for me and he even rebuilt a pair of vintage Fox Airshox for my '79 Honda CR250. Call him at 619-281-0455.
  5. 84scrambler Husqvarna
    mid Florida
    Hey Ben, I had Drew do my ohlins for my 79 wr and they work great . I would choose the forks your going to use in accordance to the correct length of the rear shock what ever they may be. I don't know O R suspension that well but 16.5 seems offly long to me for the rear twins. That sounds more like C R stuff that used the longer swing arm. I installed 40 mm forks up front on mine to they were W R forks tho (shorter bottoms) Try and find out if the or swing arm mounts are in the same spot as the cr and then go from there . Let us know what you come up with , this has been done lots of times on here. Good luck and send us some pics.
  6. NC Rick Husqvarna
    Asheville, NC
    2011 TE 449
    Dr 650, KLX, Ducati track bikes
    I totally remember my own 390 doing that. I had put a set of Koni remote reservoir shocks on mine back then. The Ohlins will be much better!
  7. JOHN MONTEREY Husqvarna
    Monterey, CA
    390 OR, 250 OR, 80/81 250 CR
    DRZ400. Harley not-so-softail
    Hi, speaking of shock parts... Do you have Curnutt top inserts with a (approx.) 12 mm hole? I'm fitting a pair in a Husky 1980 CR frame and the inserts I Have have hole diameter about half that size. Thanks! Email: jowcha@aol.com
  8. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    Yes I have the inserts.
  9. JOHN MONTEREY Husqvarna
    Monterey, CA
    Thanks Scott. How do I procure?
  10. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    Send me an email at scotmarian@aol.com
    If you have a 12mm drill bit you could drill the ones you have.
  11. JOHN MONTEREY Husqvarna
    Monterey, CA
    Thanks. I thought of that but wasn't sure that was the right thing to do.
