82 XC430 jetting baseline
Discussion in 'Vintage/Left Kickers' started by guscycle, Nov 3, 2020.
  1. guscycle Husqvarna
    Florida
    '99 Husky CR250, '07 Husky WR125,
    '10 Husky SMR450, '98 Husky Scooter
    Looking for some baseline carb settings for an 82 XC430... correct me if I'm wrong but stock was : MAIN=430 , PILOT=45 , NEEDLE 6DH3 in fourth position from top, SLIDE= 2.0 ,I CAN'T READ ANYTHING ON NEEDLE JET- some say the Q8 could be a left over from euro street specs, some say R4.
    Some thoughts on Picklito suggestion from another post...Getting ready to order up new parts as needed to update; BASE: PILOT=45, MAIN 480, NEEDLE 6DH3 @ 3 POSITION, NEEDLE JET=R4, SLIDE=3.0If I can't find a 3.0 SLIDE but a 2.5 is available, then drop to a 40 PILOT.
    As far as the air jet ,2.0 is standard but seems I read that some guys remove it to help starting.
    THANX FOR ANY INPUT!
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Niche Cycle has 3.0 slide, just got one. They are close to you and stock everything for Mikuni.
    http://www.nichecycle.com/ncs/categ...vm38-52-vm38-52-throttle-slide-by-mikuni.html
  3. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    The 480+ mains I recommend were mainly for sea level desert. Still, I think the stock size was too small. Some had 430, some 440, not sure why. I like a 450-460 for woods riding at 2000 ft.
    40
    2.5-3.0 slide
    R-4
    6DH3-3
    460
  4. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    my 430: 2.0 slide, 50 pilot, 430 main, 1 turn on air screw
    at 0 ft sea level
  5. Sladep Husqvarna
    Littleton, Colorado
    1982 XC430, 2016 TE300
    KDX220R (2000&2004),08 Honda GL1800
    Found stock was lean. Due to changing elevations all the time, am trying a SmartCarb 2 on mine. Will be here in a few weeks and will let you know how it does, if anyone's interested.
