84 Steering stem lower bearing
Discussion in 'Vintage/Left Kickers' started by firecrackerkid, Mar 16, 2011.
  1. firecrackerkid Husqvarna
    Grand Coulee, Washington
    78 390 OR, 84 250WR, 83 175WR
    Do you have to remove the stem to get the lower bearing off for replacement? Now that I broke it I need to put another one on...and not break it. Dumb Norwegian + big hammer. You get the picture, little bearings everywhere.
  2. fran...k. Husqvarna
    eastern ct
    This was the first topic I ever commented on when I joined. Generally I grind almost all the way through what is left of the bearing on the stem and get it off that way. one guy says take out the mig welder and weld on it and get it off before it cools, another may say press the stem out but it might not press out the way you think just from memory. Grind almost all the way through without contaminating good parts with abrasive dust, if it won't rotate with a punch try a little (a high heat in a small area) heat just at the thin spot and it might crack. I find getting the race out of the neck with a punch a little more tricky.
  3. Husq.fleet Husqvarna
    Pendleton Oregon
    Thats a good pic of you Geary! I think the cape would be good at Othello, really fly! The stem is really pressed into triple. I use a cut off wheel on a die grinder. Like Fran said be carefull not to get into stem. I cut into it until I get nervous then wack it the rest of the way off with a air hammer. There is also a thin washer under that bearing you will need to reuse. I use the "dead" bearing to press the new one on.
  4. firecrackerkid Husqvarna
    Got it! Thanks fellas. About the cape.... My brother and I tape a whistle tube to our helmets. It is about 3' long and the faster you go the higher pitch it gets. For some reason people look at us funny.
  5. HuskyT Moderator
    Corona, California
  6. HuskyT Moderator
    Corona, California
