'85 -88 Swinging Arm - Method of restoration?
Discussion in 'Vintage/Left Kickers' started by Husky37, Jan 10, 2010.
  1. Husky37 Husqvarna
    UK
    84 CR500, 85 CR500, 89 TE 610
    This is a general question outside of my project but for my project....
    I have stripped the paint off (almost) of the swinging arm because it was too bad to do anything with. I would like to get it back to 'naked' ally but not polished.
    I have thought about Vapour Blasting but all these treatments are eating into my budget.
    Does any body have any suggestions on how to clean up the Arm with a process/method I could do myself?
    Stu
  2. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    use # 3 or #4 steel wool
    Stu,
    Try using # 3 or #4 steel wool (roughest), it will clean off the paint
    & tarness, & not polish it. I've done this on my 91 350 & 86 400
    & it comes out great.
    Husky John
  3. Husky37 Husqvarna
    UK
    Hi John,
    I'm not adverse to a bit of elbow grease.... so I'll give that a whirl.
    Thanks
    Stu
  4. Fritzcoinc Husqvarna
    Cypress, Texas
    1986 swing arm paint
    Here's a link to some paint that is very close in color to original Husky.
    It is also much more durable than the original and comes in a rattle can. Check out " Stainless Steel Grey" for your swing arm. Note it comes in several colors and a clear as well.
    http://www.brownells.com/.aspx/pid=1117/Product/ALUMA_HYDE_reg__II
  5. Husky37 Husqvarna
    UK
    Hi Fritzcoinc,
    I have thought about paint but the works bikes were naked Ally so I would prefer to go that route first.
    I might have a problem getting it from the US. I'll see if any one imports it.
    It's a good tip to add to the list.
    Many thanks.
    Stu
  6. mike328 Husqvarna
    colorado
    Not sure whats available in the UK, But I stripped a cars Radiator Over flow tank using the high pressure car wash.
    Careful the pressure will push the part around, I grabbbed mine & the pressure blistered my skin.
    If ya can have someone stand on it (wearing boots) while Blast it off..
    shouldn't take much.. ($2.00) or one pound..
  7. Fritzcoinc Husqvarna
    Cypress, Texas
    Here's how mine turned out. Process was: weld repair, shot peen, apply Stainless color Alumi Hide, apply decal, the clear coat with Alumi Hide.
    I did the fork sliders the same way, except no weld repair was needed.
  8. endurokids Husqvarna
    Wisconsin
    250WRX, CR167, 83 430WR, TE449
    75 Guzzi 850T
    I'm going to bead blast mine and linear sand the aluminum to replace the factory lines in the metal, and urethane clear coat it.
    I wont be doing my WRX untill winter so I dont have any pics to share yet.
    Where did you get the swingarm decals at?
  9. Fritzcoinc Husqvarna
    Cypress, Texas
    EBay, search "Husqvarna swing arm".
