86 430 AE Front master cylinder Question
Discussion in 'Vintage Restoration Projects' started by Submit, Nov 19, 2013.
  1. Submit Husqvarna
    Bradford, Ontario
    2012 CR125, 86 430 AUTO
    Looking for some help here, I'm attempting get my dad's old bike going again and right now I'm working on getting the front master cylinder working.
    There's a spring in the cylinder and I'm wondering if the spring comes out? I've tried pulling on it with a pair of pliers ( may not be the right way to go about it ) but it doesn't seem to want to come out which makes me think it's not supposed to.
    Also, what is the best way to remove oxidation from the aluminum?
  2. WayneL Husqvarna
    Australia
    87 WR400 88 WR125 84 AE500 &13 WR300
    BMW R1200GS and R80G/S PD
  3. fabrice Husqvarna
    Boucau Bayonne Biarritz FRANCE
    Automatic's
    Submit
    front master cylinder 86 or 87 I have it in used
    86 brake caliper one piston , 87 two pistons , it's the best for one AE because no brake engine
    if you don't find in US I can to send it but there'll have shipping same if the master-cylinder is free
  4. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    If there's any pitting in the piston area, it's probably toast, as you need a good seal. I've got a spare master as well some were.
  5. Submit Husqvarna
    Bradford, Ontario
    I haven't had a good look at the caliber yet but I think it will be ok once I clean it and rebuild it if it needs to be done. As for the master I think it might be to far gone for me to save, It has oxidation all over the outside and it looks like it might of gotten inside it as well.
  6. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    If you want to upgrade a 97/WR master cylinder with a 87 left side fork leg and a 87 twin spot caliper work real nice.
  7. Submit Husqvarna
    Bradford, Ontario
    I've decided I'm just going to do a front end swap. Going to put modern forks on the bike instead of using the old forks.
