86 510 - motor swap into an 84 TX/TE 510 frame?
Discussion in 'Vintage/Left Kickers' started by hawaii-rider, Apr 29, 2011.
  1. hawaii-rider Husqvarna
    Graham Washington, Fort Moose
    2018 TC250, 2015 TE300
    04 CRF-270x, 95 CR500, 93 CR250 etc
    or did Husky do something to the motor/cases that would prevent that from happpening without major fabrication to do the swap.
    Thanx
    Scott
  2. scoott Husqvarna
    Goldendale,WA
    17 Huskies from 1979 to 1987
    12 KTM's from 01 to 2010.
    Bolts right in Scott, if youhave the 4-stoke frame, or you mod a 2-stroke fame......
    .Now WHY would you want to carve up a perfectly good 86?
  3. hawaii-rider Husqvarna
    dont want to carve anything
    I found two each
    1984 TE510 frames
    I race EVO, not unlimited so I have to have
    no linkage rear, drum brakes, air cooled.
    thats all...
    some of us have ONE OF EVERYTHING from Sweden...
    normal people have to piece things together....
    sigh
    Scott
  4. Husq.fleet Husqvarna
    Pendleton Oregon
    Sounds like "roost envy" to me!
  5. fran...k. Husqvarna
    eastern ct
    How about the fact the dual shock models have 12 mm swingarm pivot bolts and the mono shock ones at least as far as 1999 have 14 mm bolts which got bigger soon after that but I don't know when. I have no air cooled four stroke experience but putting (just placing) water cooled four strokes in the 83 two stroke frame the carb must be higher up on the engine I had in there than an air cooled one. I am just saying the mono shock backbone type frame gave more room over the carb whether it was needed in 86 can't say.
  6. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Isn't the 1986 510 watercooled or just MX model? If so wouldn't you need the aircooled head so exhaust won't hit front downtube?
  7. hawaii-rider Husqvarna
    86 motor is air-cooled
  8. frog Husqvarna
    MN
    This is an 1986 model with 2/1 header and Supertrap exhaust! They had most of the bugs out of the air-cooled model by 1986. John a memeber on here put an 1986 motor in twin shock frame,in restoration section
  9. scoott Husqvarna
    Goldendale,WA
    So are you going to Arkansas any time soon?
  10. hawaii-rider Husqvarna
    No but UPS IS
    Scott
  11. scoott Husqvarna
    Goldendale,WA
    Spendy!
  12. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    Difference #1 between 83-5 VS 86 4t. The surface area of the cooling fins much bigger. On Left is a rebuilt 83 head with big SS valves and porting, on right a stock 86 head.
  13. husqyhamm Husqvarna
    South Africa
    Left 83, center 500 2t, right 86. All 3 will drop into a 83/4 2T frame, just remember the 86 has a 14mm hole through for swingarm bolt and 83/4 is 12mm.
    I hope you can notice that the machined face and boltholes for inlet manifold is different between 83/4 and 86.
  14. husqyhamm Husqvarna
    South Africa
  15. husqyhamm Husqvarna
    South Africa
    Mods to fit 86 into 84 4T would be to change inlet manifold angle and length so carb clears frame tube for airbox, and exhaust headers on 86 will have to be swapped for 83/4 headers or custom system.
  16. fran...k. Husqvarna
    eastern ct
    You probably should at least investigate whether the ballance factor for the crankshaft got changed in the change of frame type and if so when. I know it wasn't in your origional question but it appears to me they changed it on the 500 two strokes at some point around 85-86 or so. And then they changed the crankshaft shape for 87 or so but since the shape is different the ballance difference isn't clear to me. I have on the two stroke side a later 14 mm pivot hole engine with custom rear inserts and the more modern crank in a silver frame (air cooled) and nothing terrible has happened yet.
