86 husky wr 250
Discussion in 'Vintage Restoration Projects' started by snfpagp, Jul 30, 2013.
  1. snfpagp Husqvarna
    Wilmington NC
    86Husqvarna wr 250
    92 KTM 500 sm
    Need help on my 86 husky wr 250 I open the top end the sleeve is need to be rebuild the bottom of the sleeve is broke off .I need a good use cyclinder or a company that rebuild sleeve
    Thanks ,Frank
  2. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Give Steve a try, he has used, some new pistons and some NOS parts too.
    www.huskydoggg.com
  3. wooddee Husqvarna
    QUEENSLAND AUSTRALIA.
    86 240 WR,09 300 WR.
    Give Ebay a try, that's where i bought mine. Mine is a 240 but my barrel was shagged so i tracked down a 85 wrx 250 with piston, still on standard ring.
  4. snfpagp Husqvarna
    Wilmington NC
    86Husqvarna wr 250
    92 KTM 500 sm
    I check ebay everyday no such luck.I'm about given up on it .My mechanic don't even want to touch it .The piston is chewed up debris all over the crank shaft .The bottom end need to be open and see what kind of damage it cost to the bottom end .i'm so into deep in it .Its not even funny .Thanks Woodee
  5. snfpagp Husqvarna
    Wilmington NC
    86Husqvarna wr 250
    92 KTM 500 sm
    Who is Steve??
  6. Ron Husqvarna
    Azusa, CA
    Steve Borejko great guy to deal with for Husky parts. www.huskydoggg.com
  7. 86 400 XC Husqvarna
    Calgary
    more Huskys
  8. snfpagp Husqvarna
    Wilmington NC
    86Husqvarna wr 250
    92 KTM 500 sm
    Thanks Ron!!
    Thanks 86 400 XC!!
  9. snfpagp Husqvarna
    Wilmington NC
    86Husqvarna wr 250
    92 KTM 500 sm
    Still need the right cylinder for my 86 Husky wr 250 .The 85 cylinder that i bought do not match my 86 .I called Steve he doesn't have a replacement cylinder for it .I guess the next step is try try to rebuilt the cylinder any idea what company close to NC state could rebuilt it
  10. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Any competent mechanic can replace the sleeve in the cylinder. They need to find the right sleeve for it. If Steve at www.huskydoggg.com does not have the sleeve you can try one of our sponsors www.hva-factory.com You can inquire at LA Sleeve. They can replicate the existing porting in your cylinder and install but that is really a last resort in vintage world. You always try to buy a part before you have one made because of the cost.
    In what respect does the 85 cylinder not match your 86 cylinder? If it is merely porting, I would at least try it. If it is an air-cooled cylinder then you at least have a cylinder liner donor As far as splitting the cases, you can do that yourself with some basic tools and carefully application of pullers. You can download a shop manual from HVA-Factory if needed
  11. husqvarna-parts Husqvarna
    85 86 pistons are interchangable
