87 WR430 disc brake conversion
Discussion in 'Vintage/Left Kickers' started by Darrel78, Nov 28, 2015.
  1. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I ended up using a COM10T bearing; had to grind 0.006" off to make it work.
  2. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    Swinger is sorted. Now to lace up the rim and figure out the master cylinder placement.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    why did you change that it looks like an 87 swingarm
    are the oem not available?
  4. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    It is indeed an '87. The replacement bearings that I was able to find were $95 or so. The COM10T is apparently still in common production; $20. The specs work out and taking 0.006" off is no big deal. Perhaps a poor choice on my end but I'm giving it a go.
  5. 2premo Husqvarna
    Northern NV
    I had no idea the bearings were that much
    thats 95x all the bearings? there are a few bearings involved
    my dealer still has NOS and he gives me a decent price on these type things
  6. 2premo Husqvarna
    Northern NV
    I am interested in how you mount your brake reservoir
    i measured the swingarm and concluded the 92 wheel fits, but i am milling my swingarm for the 92 axle
    the caliper mount seemed like the only real problem as it needed a little taken off the back to allow the wheel to align the sprocket
    what did you do with the caliper mount
  7. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I was able to source most of the required parts from Halls. That one bearing was quoted at $95 (not from Halls as it is not available from them). The good news is the bearing is still available; just more expensive than I wanted. I did not like the price on the swinger bearing parts either so decided to make them from drill rod (silver steel for those across the pond). Since I've the capabilities to do this class of work it just seemed to make sense to make them. I'm thankful they are still available as most folks will need simply to purchase them.
  8. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    Who's your local dealer? I thought only Halls was the only dealer who stocked vintage parts.
  9. 2premo Husqvarna
    Northern NV
    very small dealer, sold these when they were new
  10. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I machined the bushing to accept the 15mm axle. Made it ~ 0.30" thinner on the face and also took off ~ 0.050" from the caliper at the anchor location to allow as much room as possible for the anchor weldment and to allow the caliper mount full front to back travel. It's a tight fit but seems workable.
  11. oldbikedude Husqvarna
    Honey Brook Pa.
    Nice work. I always thought about doing that to my bike but I don't out ride the brakes anymore. (I got old)
    Darrel78 likes this.
  12. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    85-88 swingarm bearings are hk2216-2brs
    available anywhere, they are not husky specific. just like the wheel bearings, pick a good brand and just order 6302-2rs..
    if you buy them packaged as "husqvarna bearings" they are triple price..
    both of these are still "common production"
    Darrel78 and Trenchcoat85 like this.
  13. Submit Husqvarna
    Bradford, Ontario
    2012 CR125, 86 430 AUTO
    This how I mounted mine on my bike. Seems to work well and is out of the way.
  14. 2premo Husqvarna
    Northern NV
    where did you put the reservoir ??
  15. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    That 1 has a built in reservoir
  16. Submit Husqvarna
    Bradford, Ontario
    Like 86 400 XC said that one is built in. It's off a 2010 250 TC
  17. 2premo Husqvarna
    Northern NV
    that solves a big question for me
    as the air box was in the way with my 93 master reservoir
  18. 2premo Husqvarna
    Northern NV
    is there a window for level checking?
  19. Submit Husqvarna
    Bradford, Ontario
    Yes it's on the back. You can see the outline of if you look closely
  20. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    They should tell people these things...
