'88 swingarm on '85 single shock frame?
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, May 11, 2018.
  1. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Hi guys, I am impatiently waiting for shock parts to arrive in time for the Braidwood Vinduro next weekend, but I had a thought......
    If my shock parts don't arrive in time for me to complete it, will my '88 swingarm and shock fit as a temporary solution?
    I've searched and the only reference I can find is a post from 2009 by WRX, where he mentions that he has a 1987 250 swingarm on his 1985 frame, but that's all I can find.
    Have any of you guys done this and is there anything stopping me from using this combo for a couple of weeks, or are mods needed?
    Tony.
  2. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    I suspect the linkage will be different between 85 and 88 so as long as you swap the linkages also it should be OK. Check the dimensions of the 88 frame match your 85 linkage (if you have them). Can’t say if it will function OK with 88 linkage but it might be fine. Good luck.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    they want swap straight on, you need to modify the link at the back of the frame, as in move it
  4. ajcmbrown Husqvarna
    I'm also thinking that since the 85 has XC forks, that the 88 WR shock may be a little short?
  5. fran...k. Husqvarna
    eastern ct
    The shock is offset differently from the centerline.
  6. ajcmbrown Husqvarna
    Apologies guys, I thought it might work but not if it's that different. If my parts don't arrive I'll just have to make do with the 88 250WR!
  7. 2premo Husqvarna
    Northern NV
    you say that like an 88 250WR is second rate equipment, those are nice bikes
  8. ajcmbrown Husqvarna
    No, not at all Greg, I love my 250!
    It's hard to show sarcasm sometimes.
  9. 2premo Husqvarna
    Northern NV
    you mean like this :busted:
  10. ajcmbrown Husqvarna
    Exactly, but after a couple of beers I couldn't find the emoticons (or whatever they are called) on my phone! :)
    2premo likes this.
  11. 2premo Husqvarna
    Northern NV
    couldn't find them, did you count the empties when you woke up, or should I say came to?
  12. ajcmbrown Husqvarna
    A man is not a camel.....
  13. 2premo Husqvarna
    Northern NV
    ajcmbrown likes this.
  14. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    I had to cut the top shock mount off the 87 frame and graft it on the 85 frame to make it work. the angle of the top mount was very different between the two. I did this as a 20year old kid with not a lot of money and access to mig and tig welding set ups. about ten years later I grafted the two left over motorcycle halves together and sold that bike to buddy of mine who still owns it.
  15. 2premo Husqvarna
    Northern NV
    the height of the top shock mount changed as well as the linkage location to the frame, seems to have moved about 10-12mm
    the shock, ratio and linkage are worlds apart on design
  16. ajcmbrown Husqvarna
    Well my shock parts arrived yesterday, it's now assembled and back where it belongs!
    Thanks for all the comments fellas, It was great to not have to find out the hard way.
    Tony.
