125-200cc 91 WMX 125 engine in 1987 WRK 125 frame
Discussion in '2 Stroke' started by jd117, Dec 7, 2015.
  1. jd117 Husqvarna
    lake geneva
    Does anyone know if this is a direct bolt up ? The numbers don't match in the parts fiche but the mounting points on the frame diagram look really close for whatever that is worth. Both engines are right side drive also.
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    a 1987 will have mostly Cagiva badging
    a 91 is basically the same with some updates
    look at the exhaust port, if its the same exact location it should work
