250-500cc 91 WMX 250
Discussion in '2 Stroke' started by 91husky, Feb 15, 2016.
  1. 91husky Husqvarna
    wmx250
    ok all, im new to this site , im looking for some help.
    i have a 1991 wmx250. ive had it since 2008..
    it has
    -DynoPort pipe
    -FMF turbinecore 2 spark arrestor.
    -New clutch kit
    -New piston.
    i have found that parts for this bike for me are extremely hard to find...
    When i ordered the piston for this bike, they ordered one that was like 150$. turned out to be the wrong one. ( the wrist pin sat like 1/16 of an inch shorter on it and caused the piston to smack the head before it would do a full revolution), then i had them order me the correct one and it turned out to be 370$.... I need to get the damn thing jetted properly still.. will prolly do that here in a week or 2 .
    So, here are the questions i have...
    -What plastics are interchangeable on my bike with different sizes and models , because all of mine are pretty shot outside of my front fender which is obviously pretty universal.
    -Where can i find engine parts and what engine parts are interchangeable, anywhere between the carb to piston.
    -When i took apart my carb the other week . i found that the floats were different weights... is there a reason to this (its a del-orto vhsb )
    -why were there 2 different pistons for that bike?
    I know im probably asking a lot for a new guy to the forums, but i jus want my baby to look good and run right.
  2. photoguy_43420 Husqvarna
    Ohio
    11 Husqvarna's from 1973-2001
    73 Norton Commando 850
    I have a 91 WXE and shrounds are not hard to find 92-93 should work. I have a 92 set on mine right now. You might what to check Halls parts list. Not sure if the tank from a WMX is different then a WXE which would cause problems with the shrouds. I was told by Halls which has on their E-bay store a new cylinder and piston for a good price was for a WMX and would not fit a WXE. So that is why there is two different pistons. I do have a nos rear fender for a WMX let me know if you are intrested.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    good call on the piston
    but was not aware there were two
    what part of the world are you in?
  4. 2premo Husqvarna
    Northern NV
  5. 2premo Husqvarna
    Northern NV
  6. 2premo Husqvarna
    Northern NV
    wow
    looked at the Halls catalogs on 1990 and 1991 250 WMX WXE
    there are quite a few variations for sure
    seems a WXE crank or rod would make your life a lot easier
  7. Norman Foley Husqvarna
    A tough year to own.... Husky did a major revamp of the bikes for '91 and then did it again in '92. I've had the chance to buy 2 '91 WXE260's and passed, as I was afraid of parts availability. Good luck and keep looking!
    William Wallace and 91husky like this.
  8. 91husky Husqvarna
    wmx250
    I'll let you known soon on the rear fender , ya I've found the shrouds . I appreciate all the help .
    Out of curiosity what's the condition of the rear fender and what's your price ?
  9. 91husky Husqvarna
    wmx250
    The shroud from the 90 is different than the 91 . Is there a certain year set or differnt models that the cagiva is interchangeable with besides the wmx?
  10. 91husky Husqvarna
    wmx250
    as far as sidecovers go that is ?
  11. 2premo Husqvarna
    Northern NV
  12. Norman Foley Husqvarna
    OP better snap that up!
  13. 2premo Husqvarna
    Northern NV
    i reread the listing
    it gets better,,,, it's an updated as in dealer aftermarket :banana:
    better than the original and factory accurate
  14. photoguy_43420 Husqvarna
    Ohio
    My 91 WXE 250. I had this bike from about 98. Love it great rider.
  15. rancher1 Husqvarna
    WA
    I parted out a 1990 WXE 250 and I have some parts that I would give to a good home.
  16. photoguy_43420 Husqvarna
    Ohio
    Here is the fender never been mounted. I thought it might work on the WXE but different sub frame. It has some self marks where the seat would block it. The parts that would show look great. Let me know if you are interested. As any rear fenders for 91 are hard to find.
  17. 91husky Husqvarna
    wmx250
    Sweet , looks great , u have a price ?
    Also another thing . The bike has ran like ass for a long while now ,
    I have recently found the time and have decided to get to the bottom of it .
    I know it all recides with my jetting
    The bike has fresh air filter , good reeds, good spark , and the moment the spark arrestor goes on the bike runs like ass ...
    Also the packing is good in the spark arrestor
    So I took apart the carb and found that it has all stock jetting .
    However as I took it apart I found a couple things
    The floats are different weights , is there a reason to this ?
    The needle circlip has been missing
    Also the needle valve is atleast 9 yrs old
    So, I will be ordering a circlip .
    Some jets,
    Floats if I need to ,
    I will be ordering a new needle and seat soon as someone can answer me this ...
    What size of seat do I need to get ???
    Main jet will be around 182-188
  18. 2premo Husqvarna
    Northern NV
    did you grab that cylinder kit?
  19. rancher1 Husqvarna
    WA
    Someone grabbed it !
  20. 91husky Husqvarna
    wmx250
    Unfortunately I was unable to grab such a great deal, but it is ok for now beings my current piston is still good from the last time I replaced it
