92 wr360
Discussion in '2 Stroke' started by starman981, May 2, 2014.
  1. starman981 Husqvarna
    1992 wr360
    hi just wondering i have a 1992 wr360 does anyone know the compression readings of this motor ive done 1 on mine and its a 180psi acording too my tester but my main question is is the piston at tdc meant to be level with the top of cycinder? mine is 1.25 mm from the top is this normal as every pther 2 stroke ive ever worked on the piston is level with the top of the cylinder at tdc ????
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    needs to be in the other (Italian) 2 stroke section, sorry and sorry x2 i dont have anything to answer your question.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    180 psi sounds healthy, measure it again in a few rides time, yup the pustin stops short as this is for the squish clearance, you can do squish teat with soft solder and measure the gap between piston an head machine head as you see fit.
