250-500cc 95 WR360 - engine dies after 10 min
Discussion in '2 Stroke' started by belogerer, Nov 8, 2012.
  1. belogerer Husqvarna
    WR 360
    Hello all
    I have a new problem with my 95 wr360 - it starts ok at first kick but after like 10 min of riding it engine dies and it won't start. If i let it cool down for 5 min it starts well but dies again in a short time and i have to let it cool down again..
    Any ideeas on what can i do to fix it?
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Sounds like a float or fuel problem?
    Is it chewing plugs?
    Does it power through the gears?
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Start with the fuel cap breather/vent, see if its blocked or release the cap when it dies to see if that fixes it, if not its something else :lol:
    icebergstu likes this.
  4. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
  5. NvRider55 Husqvarna
    N. Nv.
    2001 wr360
    KTM 525ex, 250xc 2T, 200sx,300mxc
    Plug cap or stator?
  6. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Or the the coil is breaking down when its starting to get hot.
  7. belogerer Husqvarna
    WR 360
    First thank you all for the answers.
    Today it was very cold here and i went for a ride in town - just cruising not too fast...nothing happened..it was running perfect. I went to my mechanic and he changed my main jet from 185 to 175 and then i went home. After few hundred meters shit happened...it stopped...
    I smoked i cigarette to let it cool down and i started again...after 1km again...engine died...
    I removed the breather from the cap and it worked smoothly till i got home - seems that was the issue here - but it is strange because i tried to suck air through the vent and it worked...but when i removed it the motor started without needing to let it cool down...
    Hope this solved the problem...if not i will ask again for help - thank you all
  8. robinm Husqvarna
    1999 cr125
    crf 100, cb 400
    hi been ther done that
    if your plug cap, should be 5 ohms is stuffed this will happen
    you can find the part number from ngk site and then order it from you local car parts place
    only about 15 bucks
    good luck
    the resistor in the cap can die or you have a non resistor type plug cap
    robin
