250-500cc '96-'03 wr/cr 125, 250 and 360 rear brake pedal fitment on a '11 wr 300
Discussion in '2 Stroke' started by Brian Scott, Oct 9, 2013.
  1. Brian Scott Husqvarna
    Bainbridge Island, Washington State
    '11 WR 300
    '01 CR 500R
    I found a decent replacement rear brake pedal on ebay that might work to replace mine that snapped at the tip this past weekend. The part # for my pedal is 8A0073343. Does anyone know if this pedal will fit my '11 wr 300? Does anyone know the part # for '96-'03 wr/cr 125, 250 and 360 rear brake pedal? Thanks a bunch! I don't feel like shelling out $100 for a new oem pedal, so I hope this works out in my favor.
  2. Brian Scott Husqvarna
    '11 WR 300
    '01 CR 500R
    The pedal in question came a '99 wr 250. The part # is 800073343 (whereas mine is 8A0073343). So what's the difference?
  3. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    Yours has an A instead of a zero in the part number, It's probably the same.
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    typically if they change a color or modify it they change a number to a letter if it is a new design it usually gets a new part number
  5. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    When I was looking for a straight brake lever Bryon at BMP pretty much said there are only two brake levers for Huskies I'm 99.9% the one you have will work.
  6. rancher1 Husqvarna
    WA
    The size of the pedal tip is the difference.
