250-500cc 96 WXC clutch plates
Discussion in '2 Stroke' started by Ridingdutchman, Feb 7, 2020.
  1. Ridingdutchman Husqvarna
    1996 Husqvarna wxc 250
    Hoping someone can point me in the right direction. I’ve been searching for an aftermarket clutch kit for a 96 WXC 250 without much luck. I’ve read that possibly Honda Cr250 friction plates will work. Can anyone confirm this and If so what year Honda plates I should order. Thank you.
  2. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    95 cr 250 friction plates will work but you need 1 extra plate because husky use 8 plates.
    Good lucck.
  3. Ridingdutchman Husqvarna
    Thank you I'm going to give these a try
  4. Ridingdutchman Husqvarna
    This was good information, thanks again. I ordered a complete clutch kit for a 95 Honda CR250 and both the steel plates and friction plates fit perfectly. The springs from the kit are too long so I couldn't use them. My WXC only uses 7 frictions so I had one left over as the Honda must use 8.
  5. rancher1 Husqvarna
    WA
    Let us know how it works !
