250-500cc '96 wxe restoration
Discussion in '2 Stroke' started by 3dhunt, Dec 25, 2014.
  1. 3dhunt Husqvarna
    Woodward, Oklahoma
    '96 250 wxc
    1976 yamaha dt 175
    Hey guys, new to group here and have some questions concerning parts for a 250 wxc i picked up. I am in need of the following parts and not sure where to get them. Chain slider for the swingarm, rear roller for the chain guide, rear caliper pin, exhaust to cyl. o-ring and lastly a dreaded plastic left side cover. (new or used) I didnt know if these were all dealer parts or if I could find them aftermarket. Also another ?. are the bearings or bearing in the steering head a tapered type or not. I have some binding there and didnt know how these models were designed. Thanks for any info you can offer, great forum!!
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    welcome to the forum! very solid bike and good strong motor. most of the little pieces can be sourced from a place like halls husqvarna or ebay has some repro stuff like chain sliders and intake manifolds.
    good luck on plastics, none are available. dc plastics are lacking in a quality look for most of their products but they are tooling up to replace the plastics for 95-02. so we will see.
    i strongly recommend pulling the clutch cover and basket and inspect the kick idler gear. make sure the bolt is not loosening and there arent any case cracks there. could save you some expensive hassle. other than that these engines are very durable.
    cant tell from your photo but if it has the original double wall pipe, a large power increase and weight reduction gain is possible.
    the steering head bearings will need replaced on yours, and likely the races as well. they are a normal tapered roller design.
  3. 3dhunt Husqvarna
    Woodward, Oklahoma
    '96 250 wxc
    1976 yamaha dt 175
    thanks for the good info, i'll check with Hall's. Bike has an FMF on it so should be ok. I haven't got to ride it yet, wanted to fix it's issues first. Today I found some slight slack in the swingarm bushings and some slack in one of the shock linkages. (small end of the wishbone shaped link) I'm sure i'll have more ? as the restore continues. Thanks again!!
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    looking at the picture you have 1998 plastic, graphics and matching seat cover
    whats wrong with your left plastic, from your avatar picture it looks Ok
  5. 2premo Husqvarna
    Northern NV
  6. 3dhunt Husqvarna
    Woodward, Oklahoma
    '96 250 wxc
    1976 yamaha dt 175
    ya theres a gap between the front of the cover and the seat. The part # on the back of the cover is for the prior models. Not sure why they changed, they are so close to being alike. All the other plastics on it are great.
  7. justintendo klotz super techniplate junkie
    welcome to the italian husqvarna. some stuff stayed the same for a long time, other things would change slightly and be different
  8. 2premo Husqvarna
    Northern NV
    the seat changed shape and
    the seat shape changed and the plastic changed with it thats all
    are they pretty new or just old the reason i ask is the newer ones were easier to get and you might be able to swap with someone if they are in good overall condition
    the 92 to 94 were the same and the 95 to 99 were the same
  9. 2premo Husqvarna
    Northern NV
    repair those items right away as damage can occur quickly and very expensive to correct
  10. 3dhunt Husqvarna
    Woodward, Oklahoma
    '96 250 wxc
    1976 yamaha dt 175
    Halls had every piece I needed in stock. Now all i have left is replacing the steering head brgs and I believe the shock is leaking so off to House of Horsepower. If anyone comes across a used left number plate cover let know.
