125-200cc 99' 125WR
Discussion in '2 Stroke' started by Dean Toensing, Aug 8, 2017.
  1. Dean Toensing Husqvarna
    None
    Cagiva, Husaberg, BMW
    Hi there,
    New here, just picked up a 99' 125WR which seems to run well however there is a lot of black residue at the exhaust outlet. Can anyone advise me on disassembly of the silencer? Wondering if there is a spark arrester screen etc. that might need cleening. Also going to check mixture screw etc.
    Thanks,
    Dean
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Can't tell much from that photo, but first thing to do is clean and repack the silencer before making any adjustments. The packing could just be saturated and 18 years old! remove it from the bike and post another photo if you can't figure it out.
    :cheers:
  3. fran...k. Husqvarna
    eastern ct
    To dis assemble the silencer you drill out the rivets and pull it apart. The ends are put in with silicone sealer and I had to put mine in a log splitter, in reverse. Mine drips, I use synthetic oil. Perhaps there is some oil that is more likely to be burned up.
