99 TE610 E help and info needed
Discussion in '610/630' started by hammered, Mar 27, 2016.
  1. hammered Husqvarna
    99 te610
    I have a 99 TE610 E
    Ordered parts but they shipped me te610 Kickstart parts.
    Nothing in the package worked
    Bearings bushings extractor and gaskets all NFG.
    $300 down the drain and doubt they will exchange them.
    Spent 2 days tearing it down and putting it together.
    Adjusted the valves at least.
    The deal is.
    I'm in Costa Rica and need to source parts
    Anyone know when this bottom end changed on these electric te 610?
    2000 2003 2005????
    I need a timing chain.
    Or going to try and source silent chain here and make one
    Stock chains are crap!
    They should last longer than 20.000 km.
    Clutch basket bronze bushing and shims needed badly.
    It's getting sloppy.
    The dealer here carries limited parts and when I say 1999 and they walk away.
    hoping maybe I can use 2005 parts for example.
    Any help or info appreciated.
  2. mg94 Husqvarna
    Italy
    SM610S
    XT600
    Sorry to hear that you're having trouble. You should be good with any 610 part up to 2009, I think. To be sure, you have to manually check part numbers in the spare parts catalogs. You can find all of them here.
  3. Norman Foley Husqvarna
  4. hammered Husqvarna
    99 te610
    Thanks guys for the info and cross referencing.
    I should be able to get the parts for mid to 09 here I hope.
    I will see about returning or exchanging.
    Parts guy hasn't offered to exchange thus far.
    DID makes silent chain and going to see about buying some of this at the bearing shop in the city if they have any.
