Not sure if this is the right place for this question but does anyone know if the wr250 front wheel is the same as the wr360? My rim is bent and there's one for a wr250 on bay cheap. Thanks
buy it off him and find out im sure you emaild me the 250 is a 20mm axle and the 360 is im sure 25mm bearings may be available to suit. you could have it and swap the rim or you can buy 21" rims for dirt cheap and rebuild your wheel. would be better than an old one as ive not looked under the tyre. could be corroded. n.b. thats based on 1999 wr 250 and my 2002 wr 360 so the same year maywell be the same axle
