A pleasant surprise on my '10 TC 250...
Discussion in '4 Stroke' started by krieg, Nov 10, 2009.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    Not sure if Husky did this intentionally to all 2010's or if mine is a fluke, but my gas cap is infinitely easier to get on and off than all my other Huskies.
  2. Motosportz CH Sponsor
    Wonder if ti is different than the 09 WR125? Mine goes on pretty good and seals well. But then again i never really had an issue with husky caps like some do.
    K
  3. krieg Husqvarna
    Matthews, NC
    Many in the past
    The TXC can be a bit of a challenge. Our CR 125 was horrible.
  4. dfeckel Husqvarna
    Medford, NJ
    My TE 250 and my CR 125 are horrible. I finally fixed it on the CR by installing the IMS 3.4 gallon tank, which comes with its own cap. Like buttah.
  5. Wadman Husqvarna
    south carolina
    Im confused. What kind of problem is there with the 09 gas caps? The only problem I had was the little removable piece that Husky puts on there. It kept the cap from screwing down all the way. Once I took that off there were no more issues.
  6. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    My OEM tank on my 08/TE-510 leaked all the time. Never really thought about it once I put on the IMS tank.:excuseme:
    The 09/WR-125 cap works real good. Although I find myself using it more than I'd like to.:D
  7. Jrmobb Husqvarna
    Simi Valley,ca
    I have to tighten the cap super tight and it still will leak(from the cap not breather) if i fill the tank to high. Then it can be a nightmare to remove since i had to tighten it so tight.
    Its like the plastic binds on itself. I wish we have the ktm style.
  8. Norman Foley Husqvarna
    I never had a problem with the cap on stock tank for my '09 WR125.:cheers:
  9. wallybean Mini-Sponsor
    Montana
    +1 to what Norman said. Very nice cap from my experience.
    Walt
  10. dfeckel Husqvarna
    Medford, NJ
    My issues are, I think, out-of-round filler holes, which makes threading the cap on very difficult, and it takes a lot of force to get it to go on and off.
  11. ghte Husqvarna
    Bright, Victoria Australia
    Yep can be a tad fiddly to put back on and a real mongrel to undo as they need to be real tight otherwise they spew fuel. Tried greaing the threads a little-more trouble than its worth as it gathers gunk. Finally tore the rubber insert from the pressure and had it replaced cost 31 bucks for a piece of crap rubber-absolute rip off imho-but 24 hour turn around from R@D Husky. Price of convenience I spose.
