EricV
Hi gang. I've never pulled the engine on a TE...currently doing this to the 630.
In reading the shop manual the rear swingarm pivot bolt- that goes all the way through, side to side- functions as the rear engine mount. So you take off the 22mm nut and tap the bolt out to free up the engine. May seem like a dumb question, but does the swingarm just "fall off" then...so should I be pulling the shock, linkage, etc.?
I hope not. Yes, I know that I probably should disassemble the rear end to inspect//grease (and replace any worn bearings) but, to be honest, the engine issue is about all I'm equipped to deal with right now (in and around other time constraints, as well as by experience/skill.) For now I am more curious as to what happens when I tap this rear bolt out...and even more curious about how getting it all back together shakes out.
Thanks!
Thanks!
