A simple air box mod that works
Discussion in 'TR650' started by royal coachman, Jul 21, 2013.
  1. royal coachman Husqvarna
    Defiance, Mo.
    Terra TR650
    KLR
    Here is my take on that pesky air filter letting dirt get by................
    Just add a pre filter!
    All you have to do is get some Uni Filter material and cut to size
    This pre filter gets inserted in FRONT of the stock filter, it does not replace it!!
    You just slip it in the rectangular opening on the intake air side of the air box,
    then put the stock filter back in.
    Sorry for the crappy pic
    You are looking at the cavity were the stock filter goes
    On the left is the green pre filter on the intake side
    Clear as mud I hope:D
    This mod may cut down on some air flow but my bike seems to run just fine!
    Heck it might even richen up the mixture a tad!
    Thoughts and comments good or bad welcome
    Thanks
    Glen
    P.S. Do not forget to oil the pre filter before instalation
  2. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    Good idea my lawn mower has prefilters made of foam that lay over the paper element too......I wonder ?????
    Dinosan likes this.
  3. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Did you oil the pre-filter?
  4. Lekolite Husqvarna
    Brevard, NC
    TR 650 Strada
    What would you oil it with?
  5. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    I'd imagine something like K&N filter oil.
  6. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    That would work, just don't over oil it, or you'll find in may not run as well.
  7. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    What is holding the pre-filter in place?
  8. royal coachman Husqvarna
    Defiance, Mo.
    Terra TR650
    KLR
    Yes, UNI filter oil (the kind that comes in a spray can)
  9. royal coachman Husqvarna
    Defiance, Mo.
    Terra TR650
    KLR
    This is hard to see in the photo but it is held in place by the partition that forms the rectangular opening in front of the stock filter,
    where the air comes in.
    It is easier to remove your filter and have a look in the air box then you will understand.
  10. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Don't use K&N filter oil on foam filters, it's not the right stuff for the job. Use an oil for foam filters (Uni, No Toil, Twin Air, etc). The cloth filter oil (K&N) isn't the same stuff and even if it doesn't damage the foam, it won't stick the dirt to it as well and that dirt will just pass through. You'll want to make sure it's all evenly, but lightly coated to keep the mess down.
  11. royal coachman Husqvarna
    Defiance, Mo.
    Terra TR650
    KLR
    This is absolutely correct!
    The filter media I used for the pre filter is the same type of foam UNI uses for their bike specific filters and needs oil for foam filters!
  12. Coffee CH Owner
    This is definitely a 'must do' item, possibly with a slight twist. TBD...
  13. royal coachman Husqvarna
    Defiance, Mo.
    Terra TR650
    KLR
    :popcorn:
    hasenpfeffer likes this.
  14. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    If you ride a lot on dusty roads/trails you might want to make up a couple of pre-filters.
    I have always had a spare air filter for my dirt bikes cleaned and oiled sitting in a freezer bag.
    Any excess oil is free to accumulate in the bag and not in my air box. I think I'll spend some time this weekend and modify the air box and cut me a couple of TR pre-filters.
    Lekolite likes this.
  15. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Anyone else find their lid gasket broken?
  16. hasenpfeffer Husqvarna
    CO
    Yes, mine has a gap as well. I would think this is normal since they probably just cut a length from a long spool. Maybe a little RTV to fill it in?
  17. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Take a look at the parts manual. Its supposed to be a one piece rectangle.
    I found sand granules in the airbox, it was getting in under the seal and through that gap.
    I just crazy glued mine back together until I can get a replacement.
  18. Navelgazer Husqvarna
    Peats Ridge
    Tr650 terra
    Yes
    You will find this is on the intake sides so a well sealed filter will catch the dirt but maybe let water in if you swim it.
  19. Navelgazer Husqvarna
    Peats Ridge
    Tr650 terra
    Yes
    All good stuff, I have been working on an oiled pre filter which I have for an f800gs, sort of like a tapered Phallus, which I will push up the intake snorkel from the airbox inside so a big percentage of the dust is caught before the paper element, all of this stuffing around to satisfy the stylists and why an adventure bike has a flawed airbox design and is such a pain to replace is beyond me, I think I need a Mars bar.
  20. hasenpfeffer Husqvarna
    CO
    Actually, I do not believe this gap would be on the intake side. The sealing surface of the filter makes it so that anything around the filter is unfiltered. This gap allows air to flow into the cavity that the filter sits in, not the intake cavity. It is a small, pinch gap, so only very dusty conditions would likely be any type of problem. Simply put RTV or weather stripping or anything to fill in the gap. Heck, maybe remove the gasket altogether and put a small bead of RTV in the groove and let dry before reassembling.
