125-200cc AC lighting coil/stator for CR125/144
Discussion in '2 Stroke' started by MotoMarc36, Oct 18, 2012.
  1. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Are there any companies that offer a stator-only, or perhaps a rewind, that would provide AC voltage for my 12 CR144?? It will only be used to drive heated grips. I could just get a WR ignition? Will the WR ignition work with the stock flywheel, or am I forced to run a heavier WR flywheel?
    Thanks!
  2. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
  3. ajaxauto Husqvarna
    Rick stator Ricky stator .com can rewind your stock cr to put out 35 watts cost about 100 dollars
    also a stock batty box from a te model will fit in the air box of a cr and you can run a battery along with the 35 watts so as not to lose any power at a idle
    This is what i have done to my cr and it has worked grat since 2008
  4. MotoMarc36 Husqvarna
    wisconsin
    Many. Too many.
    Thanks guys. Does anyone know if the end product is a half-wave coil with one AC lead, or a full-wave with two AC leads?
