Acerbis Cyclops - my install
Discussion in '610/630' started by Yossarian, Apr 28, 2009.
  1. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    I put a Cyclops on my TE610 yesterday. Wow, what a difference from the stock light! I think it looks pretty decent also.
    Before installing, I took out the H3 bulbs that came in the unit, and substituted some Osram Night Breaker +90 H3 bulbs. The light output is very nice, and the whole setup cost me about $140.
    I was also able to wire it into the stock harness that I pulled off the factory light. Using a Dremel I ground down some connectors so that they'd fit into the stock connectors, which I like because if I ever need to put the stock light back on it'll be plug 'n play.
    Anyway, +1 for the Cyclops light.
    Here are some pics:
    Closeup of the light - note that the reflection from the low beam of the camera flash.
    Longer range photo.
    Dark garage, with low beam only.
    Dark garage, with high beam only.
    A quick road test revealed very positive results. I now feel that I can ride this bike at night.
  2. Coffee CH Owner
    Great review! Thanks! :thumbsup:
    Are the Cyclops DOT rated?
    Can they be adjusted up/down?
  3. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    According to the Acerbis site, the Cyclops is DOT and SAE approved.
    http://www.acerbis.com/p107_headlight/3002.html
    Yes, it can be adjusted up/down by using the adjustment trim tabs on the upper connectors where the rubber mounts straps attach.
  4. Coffee CH Owner
  5. xymotic Husqvarna
    Federal Way, WA
    When you get a chance, I'd sure like to see a front/side shot of it in daylight.
  6. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    I'll see what I can do! :)
  7. xymotic Husqvarna
    Federal Way, WA
    Thank you, much appreciated.
    Hows it do at freeway speed, does it take any pressure off your chest?
  8. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Nah, it's really not any more wind protection than the stock unit. If you are looking for wind protection, this isn't the road to take. :excuseme:
  9. jcarlson9 Husqvarna
    azusa
    headlight
    I'm thinking of getting the new led light.Is this only for looks,or does it work ?,any ideas ?:cheers:
  10. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    I've never seen the LED Vision in person.
  11. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Here are a quick couple from the garage:
  12. xymotic Husqvarna
    Federal Way, WA
    That is REALLY nice looking:thumbsup:
    Where'd the graphic come from?
  13. Dinosaur Husqvarna
    Norcal
    Looks good
    Sorry for digging up an old thread, but I was in the market for a new headlight assembly for my TE and I think we have a winner! Thanks for the pics. :thumbsup:
    Yes, where'd the graphic come from?
  14. Motosportz CH Sponsor
  15. Dinosaur Husqvarna
    Norcal
    Wow, there's a pretty big difference there. And the the TrailTech is much cheaper, too. Hmm...I must take this into consideration. :thinking:
  16. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    The graphic came from eBay.
    It's not quite as pretty now; It has "battle scars" from a jousting match with Ozark timber. :cool:
  17. Motosportz CH Sponsor
    Chicks dig scars. :D
  18. jlk_250 Husqvarna
    Minneapolis, MN
    This is a really interesting link and just the presentation to understand the differences between the lights. But I call BS! They aimed their lights properly and aimed the competitors' lights way too low. I'm sure Trailtech wants to make their lights look good but this is a dishonest way to do it. IMO, anyway.
    I have an Acerbis Cyclops knockoff and I wouldn't recommend it. I thought it was a real Acerbis when I bought it and I have no idea if I would recommend the real Acerbis Cyclops or not (but guessing no). The X2 is interesting, especially with the DOT version coming out. Personally I think the best implementation is HID low beam and HID low/halogen high beam combined for high beam. That's how I've modified my Cyclops knockoff and it's not too bad--when aimed properly!
  19. K7MDL Husqvarna
    Woodinville, WA
    On my Cyclops, the low beam glass dome is very close to the plastic protective cover and the heat has begun melting a 3/8" hole in the center. Works fine still.
    The low beam is a bit of a V pattern where the side lobes are stronger than the center. Turning on the high beam (low remains on) fills in the weak center area well.
    Decent solution I think overall.
    - Mike
  20. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    110 for a stator rewind from them too... thats interesting as its got to be a great upgrade to an enduro bike that stop starts a fair bit !
