Added Tourtech Rack
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by DougW, Aug 3, 2011.
  1. DougW Husqvarna
    Santa Clarita, CA
    I just added a tourtech rear fender rack to my "11 TE310. I thought I'd share some photo's. The bag I have on it now is a front number plate bag that is working but I will probably look for something more fitting. The rack is pretty simple to install, 3 bolts. The finish is nice as well.
  2. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Very nice. Just about the right size to keep the tools and junk out of my comeback.
  3. tl1000r Husqvarna
    nj
    Doug can you post a photo from underneath ?
    Is it mounted just in the plastic ?
    I have a 08 te450. And my rack will be here today , but the problem is they say it's for a 09 and up .
  4. RailwayRog Husqvarna
    Do you think the plastic fender will support the weight of a tool bag?
    I had mounted my tool bag directly to the fender on my KTM and destroyed the fender, had to buy a PMB rack, the PMB rack attached to the sub frame, that method with the PMB is indestructible.
    PMB does not make a rack for the 2011 310, to bad.
  5. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    I put a TT on mine as well, I knew I needed some strength underneath, so I made 3 steel brackets: 2 small side brackets and a larger, arched middle bracket, to transfer the stress to the sub-fraem, 5000 miles with some hard off-road and all is solid.
    I also added some stainless cabinet handles for bungee hooking
    WoodsChick and Picklito like this.
  6. WoodsChick Administrator
    Oakland, CA Miramonte, CA
    KTM, GasGas, Suzuki, Honda
    Wow...those stainless cabinet handles look really nice! Good thinkin'! :thumbsup:
    I am a huge fan of RokStraps. Haven't used a real bungee cord since I started using them.
  7. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    What a great and simple idea.
  8. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    I used to have a 150cc scooter that had a tailbox, the latching tab broke on it, but I saved the rack anyway. Found the other day and it was a perfect fit on top of the Touratech, makes for a bigger platform for my bag, and provided some hook points at the front, allowing me to simplify my bungee methodology..
  9. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    A thermometer on the brake light assembly... interesting idea. Looks like it was friggin cold when you took that picture, too!
  10. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
