Adding the FI map switch - 2010 TE250?
Discussion in 'EFI/carb' started by DougW, Aug 7, 2010.
  1. DougW Husqvarna
    Santa Clarita, CA
    This is in regards to my 2010 TE250.
    If one can add a mapping switch that is connected to the bike, would that work with and without having the exhaust sensor connected? As in, if the sensor is connected could you switch between 2 maps, as well as when that sensor is disconnected would you still get 2 maps?
    Thanks
    Doug
  2. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    That little switch confuses the best of them...
    Sel1 and Sel2 are ignition maps not efi Maps- but the switch only works in power up mode- so you'd have the race mode plug installed in place of the sensor- and removing the sensor from the exhaust system so it does not get ruined. Sel2 has a slightly less meaty responce down low and power completely taper's out at 6000 or 7000 rpms. Its a "wet" map.
    Here's a detailed thread on it: http://www.cafehusky.com/forums/showthread.php?t=3092&page=2
    This post answers your question:
