Adhesive foil heat shield products
Discussion in '4 Stroke' started by JCH4, Oct 23, 2009.
  1. JCH4 Husqvarna
    South Carolina
    Anyone have any opinion as to the foil adhesive heat shield you see on some bikes. Just ordered some new side plastics and was thinking of using on inside of panels to help keep them from melting. Also believe may be good to use in other places. Any opinions on good or bad and recommended brands? At first thought about header wrap but seems to not do well if it gets wet according to some.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I don't know what they are making these days, but if Moto Tiles is still around, that stuff works good. I still have a couple of packages from the 1980s and recently used some on my CR85 when I installed a new FMF SST pipe and Q spark arrestor on it. The spark arrestor was right up against the right hand side plate. Cut a piece of Moto Tile and slapped it right onto the inside of the plate. Worked like a charm. Also wrapped a radiator hose that was touching an aftermarket pipe on my 86 KX250 with the stuff back in the day, and it worked quite well on that too.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  4. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
