Adjusting preload on rear shock?
Discussion in '610/630' started by wncstrada, Dec 1, 2009.
  1. wncstrada Husqvarna
    western NC
    I'm to the point where I want to experiment with some suspension adjustments on my 08" SM610. I whipped out my trusty owner's manual and read up on adjusting the rear shock. Out to the garage, removed the left side cover, and instead of having a clear view of the shcock I'm looking at the wiring harness. How do you folks get to your rear shock? Are you using one of the special wrenches or the trusty hammer / punch method of turning the adjusters? My family wants to know why I'm beating on my new bike with a hammer!
    Thanks!
  2. raisrx251 Husqvarna
    Virginia
    Sometimes after you loosen the upper ring on your shock you can turn the spring by hand. It helps to have the bike on a stand or the suspension not compressed. You can also spray some WD-40 on the threads of the ring. Just keep your eye on the ring closest to the upper shock and see if it moves for you.
  3. Motosportz CH Sponsor
    Yep :thumbsup: Use gloves and try and grab the ring on the spring to make it all turn at once. Make sure the shock threads are real clean and lubed.
  4. wncstrada Husqvarna
    western NC
    Thanks Folks! I really appreciate the help!
  5. restukey Husqvarna
    Bethesda, Md
    The spanner tool doesn't fit my KTM if I put it in horizontal. If I put it in on a 45 degree angle, I can creap the ring nut around either way. Not sure what works on your 610? Before I learned that, I took a hammer and screwdriver to my sm610.
  6. Drew Smith Husqvarna
    Hope N.J. U.S.A.
    Using the rammer and punch is OK and sometimes the only way to get the lock ging loose. Be gentle and try to use your hands to turn the spring as others have sugested. When you retighten the lock ring just make it snug no need to beat it up it wont move on its own if it's snug.
  7. K7MDL Husqvarna
    Woodinville, WA
    I use a long large flat screw driver and rubber mallet. Loosen the lock ring by tapping it (the correct direction), then tap the load bearing ring around to position. No problems.
  8. LRPct Husqvarna
    NW connecticut
    I've always done the same with the broadest punch I can find...
  9. Owen J Husqvarna
    UK
    And you're best off attacking it from the right side (have to take the airbox off!) - much better access.....
  10. LRPct Husqvarna
    NW connecticut
    Really..?? I usually do it from the left side with the side "number plate" off. I HATE taking off the airbox ANYTIME, and lining it back up with the air boot.
  11. Fritzcoinc Husqvarna
    Cypress, Texas
    I use a 1/4" brass rod about 8" long and hammer.
  12. Owen J Husqvarna
    UK
    I agree taking the airbox on and off is a PITA but perhaps I should of pointed out I was referring to adjusting the preload using a c-spanner. You'd never get access with a c-spanner from the LHS.
    Going slightly off-topic (only very slightly!) has anyone on here managed to achieve the ride height figure quoted in the manual? I took as much preload off the shock as I could and it was still nowhere near the figure in the manual (approx 89mm IIRC)
  13. K7MDL Husqvarna
    Woodinville, WA
    The stock springs are very heavy - new springs for you unless you are 220+ or carrying passengers or lots of baggage.
    I carry lots of bagage, but mental baggage weighs nothing on a scale! :-)
  14. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Setting up the suspension is the best money I spent on mine.
    If the rear is too stiff, the front most likely is too and if you are still fighting the stiffness, you don't know how good your bike is yet.
