Hello, Curious as to if anyone knows if there are any aftermarket bar mounts that will fit with the stock top triple clamp? I know FBF makes them for the Husqvarna's and so does BRP, but I am curious if the Sunline, Applied, Tag, Pro Circuit, Easton, etc. I guess the question that also needs asked then is for what model within these brands will fit (CRF, YZF, RMZ, etc.). Just curious. Thanks! Blake
ive got 7/8 bars on mine and the protapers fit great and they are still straight after a years worth of abuse.
Does anyone know if another model complete separate top triple clamp will work? I am curious, and thought I had read somewhere (maybe here or TT), if an RG3 top triple clamp and bar mounts off another model (CRF or YZF maybe) would fit? Thanks.
I have these and love them. Great fit and look bahhhlingggy. APA Umm...their web setup won't take you to the exact page...just go to Product Overview and look for oversized clamps.
"Oversized stronger mounting bolt replaces stock bushing sleve." Huh? If you remove the sleeve you crush the rubber and not only will the vib damping of the rubber stop working but the bolt might work loose periodically or in a crash. (Ask me how i know this stuff ) IMHO you need to completely remove the rubber and go hard mount hardware or keep the sleeve.
If you choose to go with Highway Dirtbikes bark busters, paul also has risers that will work....... the barkbusters tie into the bar topclamp. http://www.highwaydirtbikes.com/HDB_Shop/
Protech enduro has some nice setups.They have a few differant mounts for roll charts ,computer mounts also.
I put some stock CRF bar mounts on and they fit the rubber bushings perfect with the inner sleeve out. But, the bolts are too long and they won't fit thru the stock bushing covers or the stock spacers. Decided to go another route for now. I prefer the 7/8 bars and will keep looking for something that'll work well.
if you go with BRP make sure they send you the bolts that are long enough. They are well made and strong, but did not send a longer bolt to account for the added 3/4 inch height.
I have a new set of risers my mate gave me unused.. Bolts are too thick so didnt fit them but also, had a special type head that recesses inside them so couldnt fit even if i wanted...well, without modification ...THEY ARE RHK MAKE !
