aftermarket brake levers 630
Discussion in '610/630' started by Ketek, Feb 4, 2013.
  1. Ketek Husqvarna
    Germany
    Hi there,
    I think there was a post about someone installing a different brake lever on the 630, but I can't seem to find it anymore.
    Has anybody installed a shorter aftermarket lever on the 630 and got a recommendation?
    -Phil
  2. organ donor Husqvarna
    Berlin
    I´ve been looking for one too. Think the only solution is to find a different make of bike which uses the same levers .... and then order them from one of the many fancy after market lever people. The problem is the brake switch activation which seems to be an afterthought on the 630 Maguras.
  3. 4l0 Husqvarna
    Sleaford,Lincolnshire. NG34
    SMS 630
    ASV Shorty Levers
    CDC602-SK (SHORT BLACK C6 CLUTCH LEVER)
    BRC555-SK (SHORT BLACK C5 BRAKE LEVER)
    just fitted some:)
  4. Sizzler Husqvarna
    Blue Mountains
    CBR600, SZR660, TLM260. DRZ250
    I got a brake and clutch levers from Midwest Mountain Engineering.
    Very happy with the result.
    Instructions that came with the brake lever-
    Remove old brake lever.
    The next step is crucial-
    Fix new brake lever- use lubricant if you like
  5. Ketek Husqvarna
    Germany
    Thanks for the suggestions. :thumbsup:
  6. stuartmcivor Husqvarna
    Kamloops
    2011 SMS630
    I had a friend cut a section out of the middle of the front brake lever with a hacksaw and weld it back together adding some built up aluminum. After half and hour with a file and some sand paper the lever was just like new but shorter and fit inside my hand guards.
  7. organ donor Husqvarna
    Berlin
    Do they activate the switches???
  8. 4l0 Husqvarna
    SMS 630
    yes buddy they do.Can do you some piccys if needs be.You got any settings yet for JD;).Going to fit mine when it warms up and EHS Filter to.But going to leave filter for a bit not made my mind up whether to fit one or not
  9. organ donor Husqvarna
    Berlin
    I´ll not tell you my JD settings right now ... as the new BMW/Husky people here changed them during the last service (or, more likely played around with the buttons) and I´m waiting for some seriously good weather to get things back to the way I like it. Did you ever find out which other bike the ASV levers fit? (Asv doesn´t list Husky)
  10. 4l0 Husqvarna
    SMS 630
    the part numbers above fit a Husky 630.Someone on here went to ASV and matched a pair.I bought mine from Calsport in Uk.I gave them these part numbers ordered a set and fitted a trick.Your right no one advertises any.But they fit trust me:D
  11. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    I cut mine stock ones down and built a ball from JBweld putty. Worked great. There are some pics on here somewhere. Cam.
