Aftermarket Heat Shield for the SM 610?
Discussion in '610/630' started by High-Side, Nov 5, 2009.
  1. High-Side Husqvarna
    I was wondering if anybody makes an aftermarket heat shield for the SM 610. Something a little smaller in size and better looking.
  2. Doormandan Husqvarna
    So Cal
    I wrapped mine with header tape. I looks good and helps with some of the heat. I think changing the can to aftermarket like an Uptite it would even cooler both ways (Cooler and better looking) and it would take some weight off.
    Note: George says to wait till you get 600 miles to change anything
    Dan L:cheers:
  3. High-Side Husqvarna
    I had a Leo Vince muffler installed at the dealer before I picked up up and the fuel injection was remapped too. I would like to change the stock muffler shield to something a little nicer looking.
  4. HDND Husqvarna
    Sydney
  5. High-Side Husqvarna
    So keep the front guard and wrap the middle.
  6. HDND Husqvarna
    Sydney
    Nice quick cheap easy fix.
    Wet it first, I used hose clamps to secure the ends of the wrap, let dry, then use silicone spray and re-apply as required.(follow OEM instructions WRT overlap)
    Did find though after a solid caining that the wrap did part in a section that my boot was touching. On trails I stand up nearly all day.
    I had an off cut and re-wrapped that bit and secured with tie-wire.:thumbsup:
  7. High-Side Husqvarna
    I went ahead and painted my exhaust shields low gloss black. I used Dupli Color engine paint and gave it three light coats. It camouflages the covers that I felt stuck out like a sore thumb. I also removed the rear turn signal spacers which moved the turn signals in about two inches on each side. Below are pictures with the black exhaust covers and with the turn signal spacers removed.
    1 wheel peel likes this.
  8. Motosportz CH Sponsor
    Sold mine yesterday and already missing it. Will really miss it next summer :cry:
  9. High-Side Husqvarna
    Sorry to hear that. :eek:
    I just got mine last month and I'm still on the honeymoon. :cheers:
    One thing nice about living in California is it feels like summer most of the year. :thumbsup:
  10. Muddy Waters Husqvarna
    On the islands
    It looks better
    I chosen not to deal with the blinker/rear light sail and just chucked it all :busted:
    Are those OEM mirrors?
    :thumbsup:
  11. High-Side Husqvarna
    Here in the Republic of Kalifornia you can't get away with no turn signals. They even pull you over for smallish non DOT turn signals and I don' want to get pulled over unless I'm speeding or popping a wheelie. :D
    The mirrors are Super Duke 2 mirrors and I found them on eBay. I like them because they are lower then the tall stock ones but work very well for the traffic I ride through.
  12. Muddy Waters Husqvarna
    On the islands
    Those are not bad looking rear views :applause:
    I do have turn signals but you’re right, they are smallish :lol:
    :thumbsup:
  13. High-Side Husqvarna
    Those wouldn't fly where I live. :smirk:
  14. AWeSomE Husqvarna
    hi,
    where do i get such a taillight? is on that taillight the turn light integrated?
  15. Muddy Waters Husqvarna
    On the islands
    Integrated indeed and the rest is here --> click <--
    :thumbsup:
  16. KillahK Husqvarna
    Victoria Bc Canada
    How do you secure the wrap at the back end? hose clamp? safety wire?
    Thanks,
    Joe
  17. Goosedog Husqvarna
    The store that sells your wrap should have the metal zip-ties for fastening it at the ends. Make sure you wrap from the rear of the pipe towards the front, that way your folds are facing back and won't fill with any grim or crude coming off the trail or street. This is an older pic of my bike but it's taken right after I repainted the wrap with silicon header wrap black paint so it shows it off pretty good.
  18. dualie Husqvarna
    2009 SM 610
    [IMG] my heat shield ripped a hole in my mid pipe, so i got rid of it. had to take the mid pipe to meineke to get the hole fixed. wrapped it, for now, as pictured. will take a look at the aftermarket shields for a permanent fix. i removed all the nubs from the pipes, so whatever i use will have to be fitted with clamps. beyond that, i got my leoV slip on today, can't wait to post pics ;o)
  19. Ger_Husky Husqvarna
    This is the Touratech Heat Shield for the 630, but it fits perfectly on the 610.
  20. BiG DoM Husqvarna
    That thing is so typically TT - fugly and over engineered IMHO. A real bad joke!
