125-200cc Aftermarket shifters for 125 / 150
Discussion in '2 Stroke' started by Vinduro, Oct 25, 2010.
  1. Vinduro Husqvarna
    Mississippi
    Where can I get an steel shifter for the 150WR ? or 125WR ?
    The stocker looks vunerable.
  2. ScottyR Husqvarna
    Mitchell, ON
  3. fran...k. Husqvarna
    eastern ct
    An older model would be steel. Mine is 1998 and I cut it and added an inch or so. The parts sheets look the same to me just different numbers. You might investigate that. I am harder on the brake pedal than the shift one, maybe just how you fall over.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Vinduro,
    I can tell you from the collision I just had with a tree/log on that side, racing. The shifter is pretty bullet proof. I was shocked not to find it broke in half.
  5. Motosportz CH Sponsor
    I'm running a hammerhead off a YZ. If your worried about it run a brake snake on the shifter side. Just run it with enough play to shift.
  6. R_Little Husqvarna
    NJ
    A yamaha 125 shifter will fit, but may be a little short.
    But keep in mind a steel shifter will eat the shaft splines. The stocker will not.
  7. Vinduro Husqvarna
    Mississippi
    Not if you keep it tight. I have never worn out shifter or shaft splines.
  8. Vinduro Husqvarna
    Mississippi
    Yes, It is a bit too short for my tastes. Need one a bit longer.
  9. Vinduro Husqvarna
    Mississippi
    Which YZ and what length tip ?
