250-500cc Aftermarket WR300 Rear Brake Pedal?
Discussion in '2 Stroke' started by hesutton, Mar 20, 2015.
  1. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    The WR300 is my first Husqvarna since I had a WR125 in high school. Been doing a lot of reading here after I bought a 2014 last month. Lots of great advice here. After reading about rear brake pedal issues, I was wondering if anyone makes an improved/beefier rear pedal for the WR300?
    I've seen a few for the white KTM's, and Italian four stroke Huskies, but nothing so far for the WR250/300.
    Thanks
    Heath
  2. gwynfryn Husqvarna
    2009 wr250
    It took me one ride to get used to the brake pedal. Totally natural now.
    I have done 70 hours with half of that racing in some pretty technical forest (stumps, clear fell etc) and have never damaged the brake pedal. It's tucked in so nice and tight I haven't even bothered with a brake snake.
    Oh yeah size 11 boot.
    Try it, you might find it fine.
    marcmo0 and Husky Gordon like this.
  3. rancher1 Husqvarna
    WA
    I would say the issues are magnified by the internet there a lot of people that have no problems at all.
    ray_ray and Husky Gordon like this.
  4. ntiguy85 Husqvarna
    2013 husqvarna wr300
    2004 yamaha fz6
    I've got the rear brake tip from Zip Ty Racing and shifter tip end and both made a big difference in feel for me. And just a side note I had Ty Davis do my suspension as well and it is amazing.
  5. jerbear610 Husqvarna
    Sacramento,CA
    14' WR300, 11' TE511, 06'TE610 sold
    11' Husaberg FE570, 15' Beta 300RR
    I agree with O.P. I've learned to live with it and I use the front brake most of the time anyway but if there was a better replacement out there I would buy it in a heartbeat.
  6. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
  7. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    i took my pedal out and straightened the whole pedal out in the press.
    took me 5 min and it fits perfect now. But if you want you can fit a TE 450 510 one from the 2008 2010 model.
  8. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Like this???
    http://m.ebay.com/itm/231504511980?nav=SEARCH
    Heath
  9. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    try it.
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I bought a nice replacement tip, anodized red with replaceable teeth, then I got used to the stocker too. I use a lot of rear brake and like the lever bend and length. Still gonna replace that tip though.
  11. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
  12. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
  13. Schrup Husqvarna
    Tacoma
    2013 WR300
    I thought about straightening mine, but it's cast & I was afraid it would break or worse, fail when I needed it badly. I got used to the stock one & haven't given it much thought. The one ordered looks nice & I wouldn't mind adding a little bling if it works well.
    Motosportz likes this.
  14. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
  15. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Will see.
    It'll be brake snaked to the bike and it's got the folding tip too. I'd rather have it a bit further out than too far in where my foot isn't dabbing the air rather than the rear brake. I've got a trip planned to Burning Rock WV in May. It should be a nice ride (looks nice anyway, never been there) and should be a good test of the new pedal.... if it fits.
    Heath
  16. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Looks like it will fit just fine. The bushing for the master cylinder pin looks to be too small and will likely need to be drilled up a few sized to fit the WR. But, that's an easy mod. Hope to have some time this weekend to mod and mount it and take some photos.
    Heath
    454x and Schrup like this.
  17. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    So, here is the new lever.
    Here it is next to the stock WR300 lever.
    You can see the bushing for the master pin is too small and few mm's too wide.
    Heath
  18. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    A 5/16 drill bit was used to get the bushing to the correct diameter. I used the trusty bench grinder to decrease the thickness of the bushing too. It was a couple of mm too thick for the master coupler.
    Here is the modified bushing.
    Here it is mounted on the bike and ready to ride.
    Quick trip around the neighborhood makes me happy with the swap. Much easier to reach and use. I haven't had time for a real ride, and I need to figure out where I want the brake snake to anchor, but I'm happy with it.
    Heath
    shawbagga, 454x, Schrup and 2 others like this.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Exhaust mount if it will reach, Low down and far forward dont restrict movment.
    shawbagga and hesutton like this.
  20. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    Just a quick update after riding with this pedal on the bike for a while.
    It was worth the $60.:thumbsup: Never missed the pedal (biggest advantage:banana: ) and it never snagged on all the rocks, logs, and other crap I have ridden through.... so the fact it is located a bit further out from the cases isn't a problem. The traction on the tip is excellent even when covered in mud.
    Just my impression.
    Heath
