Air box access to new pod filter.
Discussion in 'TR650' started by zeph, Apr 7, 2014.
  1. zeph Husqvarna
    Auckland, NZ.
    Tiger 800XC
    Thanks to those who put this modification online. Completed mine yesterday with just a couple of slight extra differences.
    I couldn't figure how to disconnect the fuel pipe so I removed the screws and lifted out the fuel pump.This meant I could raise the tank much more and it made removing the air box very easy.
    To access the filter pod it seemed easier to have the front section of the top air box cover cut open. It was easy to make two straight cuts with a fine bladed metal hack saw.
    I cut the base of the bend on a slight slope so it tilted down into the air box when fitted over the inlet. This gave a bit more clearance for the pod filter.
    The bike does have a bit more induction roar and seems to be a little smoother.
    Kenneth Webb likes this.
  2. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    Is the pod made at a angle ??? What is the part # and source of the filters you used ??
    Thanks
    Rod
  3. zeph Husqvarna
    Auckland, NZ.
    Tiger 800XC
    This a direct cut and paste from Quirky's post on Adventure Rider. I used his information to buy my parts.
    See the link on our forum to the ADVR site on how to do the air box mod. http://www.advrider.com/forums/showpost.php?p=23687271&postcount=3347
    "From UNI Filter in the US. 2 stage foam filter Part # UP-6229AST (reminder the "A" is important for the 15 degree angle)
    From Silicon intakes. 90 degree 2.25" elbow Part # SIL000360
    Silicon tube joiner 2.25" Part # JOI000111
    From UNI Filter in Oz. Crankcase breather pod, 13mm intake 40mm x 40mm."
    run-it likes this.
  4. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Here is the video on how to do the mod without removing the airbox. It is official, we modded one successfully
    http://youtu.be/a_5mKsVW_-Y
    LainattheWired likes this.
  5. drzcharlie Husqvarna
    Thanks for posting that up.
  6. zeph Husqvarna
    Auckland, NZ.
    Tiger 800XC
    I now know how easy it is to remove the pipe that goes into the fuel pump.
    Just push down on the clip at the base of the pipe where it enters the pump housing and lift the fuel pipe up and out.
    Way easier than when I lifted the whole pump up to remove the air box.
    Thanks to the man who put up the link to the full 301 page workshop manual.
    mag00 likes this.
  7. DerBrizon Husqvarna
    2005 Suzuki SV650S
    You were able to do all of the work necessary without removing the airbox at all? Does this include drilling holes/crank case breather mod? I'm ordering parts to do this now. :P
  8. drzcharlie Husqvarna
    If you have the side panel off on the right side, the radiator scoop/shroud off on the right and the radiator loosened and dropped then you should be able to drill the hole for the crank case filter relocation from the bottom of the air box (maybe).
    DerBrizon likes this.
  9. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Yes, mod was done in place. Really only needed to remove the left panel.
    I haven't done the breather mod. There is a coarse filter material within the box. I might get a small inline gas filter and just add it into the hose. Probably would be a good idea. The filters I have seen by others sure can't hurt either.
  10. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I did mine this way, although I cut closer to the 3rd screw to give myself more clearance when cleaning the Pod
    I was not happy, given how meticulous I am reading air filter cleanliness to find find dust in the airbox & throttle body
    I also cut around the rubber, using it to give an accurate circle
    Used my Dremel & a hole saw, then a soldering iron to clean up the edges
    Two lugs on the front of the seat fit under the airbox lugs, supporting the airbox
    I'm looking forward to fitting the Pod (& pleased that I might never have to remove the OEM air filter cover plate again)
