air filter
Discussion in '4 Stroke' started by audible, Mar 22, 2010.
  1. audible Husqvarna
    Temecula
    Finally got around to pulling and cleaning airfilter on my new-to-me TE450. I expected the original one, but turned out to be a "Twin-Air". I have heard many good things about Twin-Air filters. However, it did not look special to me...not even dual element like Uni?????
  2. I believe twin air is stock on most Huskies, I prefer the Moose filters just for the fact they have the neoprene at the base, I hate greasing.
  3. audible Husqvarna
    Temecula
    Stock...wow. I'm not used to a bike coming with all the good stuff already installed.
  4. Motosportz CH Sponsor
    We sell these on our site and I love them. Best air filters i have ever used.
  5. audible Husqvarna
    Temecula
    ...Twin-Air or the Moose????
  6. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    Twin-Air is the stock filter. I have been very happy w/mine.
    It is a dual element type filter. Very user friendly from my view.
    :cheers:
  7. Motosportz CH Sponsor
    Moose. The Twin-air that comes stock is good stuff too. :thumbsup:
  8. audible Husqvarna
    Temecula
    I have the cage, and outer filter with "Twin-Air" on the outside...is there supposed to be another part...?
  9. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I have 2 twinairs and 1 moose- I preferr the moose- it is slightly smaller and easier to mount correctly- It seams more durable and the neophrane is confidence inspiring. If you buy a second or third airfilter to have spares- get the moose:cheers:
  10. HUSKYnXJnWI Husqvarna
    09TE450
    No its molded together- your UNI was two pieces not molded together- the Twinair (and most others) are dual element-but molded-glued into one piece. See the inside/outside have different composit foam and color- that's dual elements:thumbsup:
  11. Motosportz CH Sponsor
    I have always though it ironic the "Twinair" is one filer while "Uni" is two filers (one inside another).
  12. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    I will probably try the Moose the next time around. For you that use the Moose, have you had any issues not using rim grease since it has the neoprene base? I'm curious if any of you still use rim grease on it?
  13. Motosportz CH Sponsor
    I use no rim grease, no issues.
  14. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    Do the Moose air filters have the rubber grommet at the wing-nut? I had 2 that did and ordered 2 more and they did not. The ones with out got sent back. I want some more Moose filters with the grommets but have not been willing to chance a blind re-order with my local not a Husky shop.
