125-200cc Air Filters
Discussion in '2 Stroke' started by Submit, Feb 23, 2014.
  1. Submit Husqvarna
    Bradford, Ontario
    2012 CR125, 86 430 AUTO
    Anyone know if any other manufacturer's air filter is compatible with the huskies?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    as in other brands of bikes, no
  3. dirt addict Husqvarna
    Southern Kalifornia
    2014 cr125
    Pro X makes air filters for the cr125. I got some from Rocky Mountain.....
  4. Submit Husqvarna
    Bradford, Ontario
    Are they good? I've always used twin air with no problems but always looking for something new and different.
  5. 2premo Husqvarna
    Northern NV
    so the question has to do with other brands than the OEM at the dealer
    the OEM is Twin Air but I have used a number of different brands but seems the Twin Airs hold up better than most
    you get what you pay for in an air filter, a little dirt and your top end is toast
    the cheaper ones seam to fall apart as in become crumbly early on
  6. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    Moose makes some with a nice rubber seal built in.
  7. dirt addict Husqvarna
    Southern Kalifornia
    2014 cr125
    I like the pro X. They seem to be as good quality as the oem. JMHO. I use No Toil oil too. So far, so good...
  8. knucklesdad Husqvarna
    Sunshine Coast Australia
    CR 65,CR144,TE510,Tc85,Tc125,Fc450
    ,HD sporty1200, ttr 50, pw50, Ktm 50
    Check out Funnel web filters from australia we run them in all our bikes, the unusual spiky shape gives more surface area, helps to keep filter cleaner for longer.
    shawbagga likes this.
  9. Submit Husqvarna
    Bradford, Ontario
    I've actually looked at those online but if I remember there is no American or Canadian dealer form them.
  10. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    hiflo filtro I think theyre called(exact same as twinair). seem good to me. funnelweb also seem good & look cool
  11. 72racerx Husqvarna
    Melbourne, Australia
    13 WR144
    01 VFR800
    Maxima also do air filters. I am using one on my 125 seems to work ok, but I don't like the fit compared to the OEM Twin Air unit.
  12. knucklesdad Husqvarna
    Funnel web will proberly ship them to you, not cheap but cwork real well.
  13. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    careful with NoToil and this type of Moose, i used to run those, and liked them, until the NoToil ate the neoprene seal. kinda melted it and made it stick to the cage like glue. had to destroy the filter to get it off.
    i've been running the pre-oiled NoToil filters lately. pretty cheap ($16.99) so i just toss 'em out after a few washes/uses.
    wish the LoudMouth system i ran on my TC fit the WR, loved that setup with a TwinAir filter.
  14. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    The NoToil green stuff will eat filter glue, but I've had no issues with the red (alcohol) based stuff. No Toil actually replaces a few air filters for me due to this.
    And filters from steel framed Honda's fit perfect after you punch a few holes for the air filter cage. I ordered 4 filters for a 1996 CR250 and these filters fit the WR300 as well as 125's.
  15. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    yeah, i ran out of red stuff and used a buddys green stuff a few times... filter was toast. NoToil was great about covering filter replacement and said not to use it on Moose filters again (just in case)
  16. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    Had the exact same issue so I switched to a TwinAir.
