Hi all, I am trying to remove the airbox and I need to completely separate it from the throttle body, but the coupling is really tight and I am afraid of braking something. Anyone has a tip for me? thank!
the box is only pushed onto the throttle body and should come off with a little wiggling of the airbox. Did you remove the annoying screw at the bottom of the airbox to the front right behind the radiator? You also have to tilt the rear frame all the way down to get the airbox out (no need to disconnect any cables). The only thing that can brake off easily is the stub for the drain tube at the bottom of the airbox. Be careful there and also be careful to not connect the crankcase vent hose to the wrong stub.
