Aluminium Polish
Discussion in 'Vintage/Left Kickers' started by mike328, Dec 3, 2010.
  1. mike328 Husqvarna
    colorado
    I got some weak acid on the aluminium engine case of my Bull.. I have a dark gray blemish about the size of a cell phone on the case...I want to bring it back to its luster..
    I have some 'mothers' metal polish but not really happy with that.
    anyone have any 'recommended' aluminium polish?
    I know its not "Husky"....but it's 'vintage'
  2. Ruffus Husqvarna
    The best I've ever found is autosol (comes in a toothpaste type of tube), just put a little dab on a cloth wrapped around your finger & do small areas at a time, you'll feel it go from slightly rough to mirror smooth, then with a clean cloth, buff it.:thumbsup:
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    By chance is the case anodized, painted, clear coated aluminum?
    If it is, gonna be a tough one!
  4. mike328 Husqvarna
    colorado
    thanks Ruffus I'll look online for autosol....
    But still open to suggestions...
    none of the below... just a polished cast aluminium case..
  5. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    X2 Autosol
    :cheers:
  6. Ruffus Husqvarna
    Found at better Harley shops everywhere :lol: :cheers:
  7. White Husky Husqvarna
    UK
    x3.
    Brilliant for cleaning chrome, stainless or any metal. It's literally a metal polish.
    Good luck!
  8. HardCoreHusky Husqvarna
    South Carolina
    1991 350WXE, 2004 TC450
    01 Royal Enfield Bullet, 91 KTM 250
    I use Blue Magic polish. Advance Auto, and I think Walmart may still carry it. This stuff always gave better results on the polished bits of an old Triumph Bonneville I had vs the other redily available polishes. It has a finer jewelers rouge than many other brands
    :thumbsup:
  9. mike328 Husqvarna
    colorado
    tough decision gonna get both... LOL..
  10. NZHusky Husqvarna
    Napier,New Zealand
    AUTOSOL -best by far:thumbsup:
  11. mike328 Husqvarna
    colorado
    I went to 3 bike shops..2 of the biggest Harley dealers...no autosol!
    ordered it on the phone...
  12. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Autosol --Aluminium polish as they said --:thumbsup:
    Autosol also make a Plastic scratch remover polish and a metal one --
    Going to need a lot of elbow grease --hehe --but works well
  13. retro rocket Husqvarna
    You might want to try a 1000 grit wet and dry emery paper first to cut through the discoloration - Aluminum is pretty porus and it may take a while to get back to bright metal with the polishes mentioned above (they lack serious abrasive cutting ability which may result in hours of polishing and no result) most of those polishes are simply a grit compound held in a paste - equivalent to a 3000grit emery paper (approximately)
    I would test a fine grit paper with plenty of water on a spare peice of alloy casing and then once the emery paper is slightly worn in and you are sure that you are not going to damage the surface attack the real stain.
    If you wanted to do away with the pastes althogether then fit a cloth polishing mop to a drill and do the final poilish using a hard polishing compound such as a rouge - or alloy specific polish compound (all this can be found at Home Depot)
    The advantages of the right wet and dry paper followed by a drill powered polishing mop is that you can cut back metal and bring back a high or low finish polish to alloy very fast...
    Avoid trying to repolish anodized or clear coated surfaces - giant head ache! (as noted by others in this thread)
  14. Gord Husqvarna
    New England
    If it was as easy as the side of the can says it is to polish aluminum, everyones aluminum would look like chrome. To fix and polish what your talking about you need electricity. This is a great kit. And by using your drill, you can leave the cover on the bike. Although it would be a lot easier taking it off and doing it on a bench.
    http://www.caswellplating.com/buffs/alpolkit.htm
  15. mike328 Husqvarna
    colorado
    wow I like that kit.. To be honest with ya... the stuff at home depot is VERY limited or non existant. I am gonna try 0000 steel wool and some other stuff I got "Gords".
    http://gordsaluminumpolish.com/
    by the time I'm done I'll have an entire 'polishing shop'...LOL
  16. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Use fine Steel wool
    I've used industrial grade steel wool (Home Depot), they sell a bunch
    of different grades. The Fine to Very Fine will work awesome, with
    surprisingly not to much effort.
    Husky John
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Watch the segment coming up in the 06 Wr125 redo. I am going to show how to polish the engine covers, swingarm, triple clamps and etc..... I go pretty fast with a showroom finish.
  18. mike328 Husqvarna
    colorado
    great thank you
  19. Gord Husqvarna
    New England
    Looking forward to it. Please let us know where we can see this.
