125-200cc Amsoil interceptor oil
Discussion in '2 Stroke' started by huskybear, May 16, 2013.
  1. huskybear Husqvarna
    B.C. Canada
    I have been using this for a while now at 32:1 in my wr150 with good results-little spooge,smoke. I recently replaced the stock pipe with a fmf fatty and I took a look at the piston and cylinder while I had the pipe off. I am very impressed with the cleanliness of this oil,I had a look at things before when I was running other oil(yamalube,motul)and there was residue on the power-valves and piston crown. Now every-thing is very clean and has a nice coating of oil on it. I know every-one has opinions on what oil they like and what they think works best, but I just wanted to put this out there. It's good stuff:thumbsup:.
  2. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I agree, its mainly what I've run in my husky 125's for over 4 years. Never much build up on PV's or piston crowns. I also like castor 927, although its only the other people I ride with that benefit from the smell.
    huskybear likes this.
  3. john01 Husqvarna
    Powhatan VA
    Yep it's very good oil. I run their Dominator with the same results for years.
  4. Motosportz CH Sponsor
    I have run dominator or interceptor for many years now. Love that stuff. Zero issues and one amazing story of flogging my 125 with zero coolant on a hot summer day for 50 miles I 100% believe in this stuff. It is all I run.
    huskybear and wallybean like this.
  5. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Yep Intercepter works for me.
  6. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    450 SMR, TE250, CR125, SM610
    Duc, Buell, Honda
    What is the difference between Dominator and Interceptor?
  7. Motosportz CH Sponsor
    dukepilot likes this.
  8. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Actually Dominator has the higher flashpoint of the two. I've been mixing Interceptor and Dominator but once I run out of Dominator I will probably use Interceptor from then on. I think Interceptor has more corrosion protection then Dominator. Dominator is more for the hardcore racer that is running it harder and frequently inspecting his engine. I don't think there is a better oil than either one of them especially if you are running race fuel.
    huskybear, jmetteer and Motosportz like this.
  9. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    Here is a shot of my 125 piston after 88.7 hours of Klotz R50.
    Here is that same piston 55 hours of amsoil interceptor later, the last 26.4 of those were with the lectron. Something is running much cleaner... not sure if I attribute it to the oil or the carb. Overall I think the piston looks good for a 125 with 143.7 hours on it.
    Later,
    wallybean and Blakelpd5 like this.
  10. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    One other factor with piston crown deposits is jetting. Lean, hotter running jetting will cause more carbon buildup on the piston crown, while richer jetting will give more "piston wash" or less build up. Although I think that the solvent in some oils keeps the piston cleaner regardless.
  11. Motosportz CH Sponsor
    I have rebuilt my 125/165's several times while using amsoil the entire time (been using it for years) and very impressed how clean the piston is and how free the power valve is.
    Piston on the right has a gob of miles on it with amsoil and Lectron.
  12. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    That's weird jmetteer I have had the exact opposite results with r50 that's the only thing I will run and I run it at 50:1
  13. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I only swapped because I was having an issue fouling plugs, that ended up being low compression. I stayed with amsoil based on cost, it is about half the cost of R50. I run both oils at 32:1 in my 125, it spends some time at high rpm so I like the extra protection.
    Later,
  14. bdl507 Husqvarna
    New Hampshire
    99 wr360
    That's not a real good way to compair then
  15. Motosportz CH Sponsor
    Jake is a good friend that lives just up the road and we ride some. He had been running the R50 for quite some time I believe so has a long history with it before switching.
  16. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    I've never had any oil foul plugs, it's all jetting.
  17. bdl507 Husqvarna
    New Hampshire
    99 wr360
    I'm sure he is a great guy (he rides a husky) but having running issues on a piston well past its life span I didn't think was a good way to compair it is awesome to get 88 hrs out of a 125 I don't know any other brands that get that
  18. Motosportz CH Sponsor
    Like I said he was running that oil when that piston was new and probably also on the piston before that. Nothing wrong with your choice of oil in the R50, there are lots of good choices.
  19. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    That's not a real good way to spell compare :banana:
  20. bdl507 Husqvarna
    New Hampshire
    99 wr360
    Lol that why I fix things for a living not teach. I use my cell phone for this forum I should make more mistakes then I do using a tiny screen.
