Another 610 Subframe reinforcement
Discussion in '610/630' started by Xcuvator, Jan 26, 2013.
  1. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I haven't had a problem with my subframe because the DirtBagz mounts do a lot to beef up the tail of the subframe, but decided to do something so there would be less to worry about especially on solo trips.
    I did the usual gusseting of the "fingers":
    Added some small gusset plates to the battery tray:
    I decided to address the "tail fixture" in a way not to add stress to it by welding it all up solid, but instead bolting it together so the stresses can be spread out by slowly tightening the bolts:
    duanew, DYNOBOB and juicypips like this.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    sweet im liking the mods,
  3. duanew Husqvarna
    2006 TE610
    WR250R XT225
    I had mine reinforced last week. I traded a bike with a guy and the TE610 came with subframe problems. The whole battery tray was broken off and repaired with custom aluminum brackets (also broken) and bolts. The left rear subframe finger was also totally broken off. The back exhaust bracket was also broken so I cut it off and am going to rebuild off of the new welded gussets. Your welds on the battery box look a little better than mine. I cut out the aluminum and took it to a local welding shop. He was not a master welder but he did better than I would have done.
    I really like your subframe bracket reinforcements. I might have to copy that. It is really the only area that needs strengthening on mine now.
  4. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Looks like you are good to go with what you have done. Yeah, there are so many forces that come together at the tail bracket from the inner fender, rear fender, subframe and in my case the dirt bagz brackets, that a little adjustibility and flex seemed important.
    As a side note,
    I had a gusset cut and fitted like yours on the RHS and the welder told me it didn't to be that long, so it got cut down. I still like the look of yours better.
    Also I just happened to have a can of Krylon Chrome Aluminum #1408 and it so matches the subframe silver anodizing that I can't even believe it.
  5. duanew Husqvarna
    2006 TE610
    WR250R XT225
    I am not planning on applying any finish on the new aluminum. Most of the aluminum gussets will be covered up by body panels anyway. Is there any reason I should?
    I had actually made some small gussets for the top of the subframe fingers but the welder thought that they were totally unnecessary. They were left off.
  6. MT VIKING Husqvarna
    BIGFORK MT
    06 TE610
    Hey thanks. Ill show this the welder Im going to use for my bike hopfully the pitchers will help. If this becomes to much of an hazzle it might be time for a new bike.
    Dale
  7. 1lunger Husqvarna
    Bloomfield CT
    Please show me a close up of your bars and damper!!!
  8. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Good timing, I was just doing some photobucket stuff.
  9. 1lunger Husqvarna
    Bloomfield CT
    How do you like those bars? Can you adjust the height on them at all?
  10. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The bars are good. I have them on three bikes.
    No height adjustment, other than what you get from rotating in the clamps like standard bars.
  11. Motosportz CH Sponsor
    Nice work, bike looks well massaged.
    K
  12. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Haha, you just like that damper-:rolleyes:
  13. Motosportz CH Sponsor
    ha ha ha yeah and the Bills sticker on the X2, where the heck did he get those? I want one.
  14. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Thanks, Yeah, I think they came out pretty good. Actually I had Mathew @ Decal Works make it up, thinking that Bill might like it and make a batch. I had it on the bike before the Fall Gathering, but after the snow started I didn't have the 610 (think 165) out much and Bill didn't see it. Kinda forgot about it to tell the truth....
