Another cooling system woe
Discussion in 'TR650' started by RockinRod, Jul 9, 2014.
  1. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    79 GS850G, 99VFR800Fi , 04ST1300A
    Guys,
    earlier this year my Terras cooling system went haywire, I read the threads checked fuses, relays, sensors and finally got to the culprit ...the fan motor. Everything else was good except when I plugged in a new fuse and powered up the bike, bam it would blow, I tried one size fuse in amp up for giggles and it blew as quickly. To satisfy my curiosity, I d/c'd the fan put in another fuse and with my 12 volt tester found power was coming down to the fan...
    So yesterday a friend who is just back from a disastrous trip to Ak on his 1200 GS and I went to the closest dealer for KTM and BMW there is where my Terra came from...they still have access to parts fiches ...while my bud was testing bikes me and the parts guy tried to find a cooling fan on the fiche, long story short its not listed separate from radiator, like where we find the thermostat, in the right side tank on the radiator....Weird design, even more weird the fan was awol....
    I got the name off the fan motor searched it and they are all over the aftermarket world, got a good source bookmarked and soon as I can pull the fan and measure ,I'll get me a new fan on the way....I had looked at several of the BMWs on the floor at the dealership and to my amazement they are on most of their bikes too.....I priced one for a GS650 and it was ridiculous as it could be imagined....on line they started at $50ish dollars US. I'm glad it was as easy to diagnose as it was
    sort of let down by the mfg for the sketchy fiches, even in one of the on line svc manuals I found here there was very little referenced by the mfg...Soon as I get back from a short holiday I'll roiund up the new fan, get it on and report back and update this thread....
  2. V8Astro Husqvarna
    Central US / Missouri
    2014 Strada / 2008 SMR510
    Suzuki GS500, Yamaha TR125L
  3. wferrari Husqvarna
    TR 650 Strada
    V-Strom
    Forcing the end user to purchase the fan in bundle with the radiator is anachronous at best, borderline fraudulent at worst, considering how the fan is one of the most likely components to fail.
  4. drzcharlie Husqvarna
    So, here is an not so obvious question (at least to me). Where is the thermostat that turns the fan on? Is it built in? I will check the schematics but just wondering if anyone knows.
  5. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    The ECU would signal the fan relay by using its coolant temp sensor.
  6. duibhceK Husqvarna
    Chapel of the Well, Belgium
    TRX850; WR450F; XT660Z Tenere
  7. Baddrapp Husqvarna
    Yucca Valley
    TR650
    It looks like the thermostat is a standard bmw part #17111464985. The schematic is to small to see on my phone but it looks like the same one. They are running around 43.00.
  8. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    AH HA,
    To complete this little journey....I and a friend got together and with the aid of an analog multimeter, we double checked all electrical components we could, ruled out the relay the fuse blew but a new one is in place and now holding fine. There are three relays under the seat and good news is they are all the same, and all of mine were working. We checked the temp sensing unit, has continuity and receiving a signal from the harness.I did find the thermostat, its in the radiator tank on the right side as you are sitting on the bike looking down. I took the number from the fan,searched it and found the mfg ,Spal an Itralian firm has an office out in Iowa. They won't take direct orders but are set to take an online order, with Fed Ex to deliver. I had replaced the very weak Castrol coolant with some locally sourced "engine ice" from cycle gear.
    I got the fan in pretty short order was about$80.US and about $8 for shipping and it came with a different connector that OEM of course.
    Its a "weather-pack" automotive style, similar to the ones on the bike, just larger, found them on line through Dell City {electric supply house}
    I could have tried to use the old original connectors but I had disassembled the connectors to find a nearly scorched alloy pins and felt a better connection was in order, I sourced a weather pack female connector locally soldered them in used shrink tubing on both wires re-wrapped them
    then set about to install the fan. It is held in place with some bolts that go through the radiator, actually they are adaptors that accept Phillips head screws, if I'd thought about it I would have gone to a hex head screw/bolt its a tight place for one of these and I could see me rounding one of those buggers out, thanks to good tools it was fairly painless. I got my buddy off the lift, backed him out onto my patio and fired him up, watching the temp gauge rise I was hoping and hoping then it kicked in, talk about relief....I'm sure that for the most part everyone here with a Terra or a Strada that has been Terrafied we like enjoy love our bikes but this has given me pause to think about a different bike....I have set my bike up with different goodies like so many of us have and its ready,set to go...but what is next to creep up on me? I'm gonna roll the dice and let them fall where they may , I like my Terra still for all the reasons I bought it in the first place....and am glad its fixed, LET'S Ride
    Rod
    Addendum;
    Well went out for a short ride to check whether or not I was successful in my repair...
    I was the fan kicked in kept the temps under control....gonna verify coolant level this afternoon...so far so good!
    Rod
    nev.. likes this.
  9. drzcharlie Husqvarna
    Do you have a link to the fan source and the part number please? I'd like to put it in the Parts Index in ADV.
  10. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    Howdy DRZCharlie,
    That's a really good idea, as our bikes have been made obsolete any source for support parts will be invaluable in the future.
    Going through the online svc manuals I could find was a great help, even better than my dealer, on his fiche it wasn't shown by apart number.
    The company is SPAL USA
    addy: 1731 SE Oralabor Rd
    Ankeny Ia 50021
    Tel: 1-800-345-0327
    Web : www.spalusa.com
    Lastly the part number for the fan is VA37-A101-46A
    its a 5.2" 12 volt fan
    foot note for future reference, they wont take orders via phone , but on their secured site....
    Rod
    Quirky, glitch_oz and V8Astro like this.
  11. drzcharlie Husqvarna
    Thank you Rod, I have added it to the Cooling section. Much appreciated.
  12. Loneranger Husqvarna
    bradenton Fla
    2013 Strada tr650
    1996 Honda XR250L,1979 Honda trail90
    I note that you celected "engine ice" over the Castrol coolant, saying the Castrol was weaker of the two. What makes the Engine Ice better? I assume you researched the coolant and had a reason to use this brand over the OEM recommended brand. I am just asking because I like to run the best in any engine additive such as lubes coolants, brake fluid etc. in order to extend the life of the parts and to help insure dependability over the long run. Where did you find the engine ice at?
    Thank you,
    LR
