250-500cc Another premix question
Discussion in '2 Stroke' started by 24valvecummins, Mar 10, 2015.
  1. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    so i know this topic has been beat to death and ive read alot on here, but i just bought a 2014 wr300 and cant decide if i should run 40:1 or 32:1. i would like to figure this out before i tune my lectron. thanks for any input.:thumbsup:
    -pat
  2. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    I run 40:1. I broke mine in with a tank of 32:1 and had so much spooge after a short ride, oil was running out the silencer and dripping on to the swing arm!
    Even at 40:1 with the keihin there seemed to be more spooge than I would expect. I run my left kickers at 24:1 with virtually no spooge.
    I was supposed to be trying my new Lectron out today but it's raining here so it will have to wait until tomorrow.
    Who makes that skid plate? I like the pipe protector built on to the front!
  3. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    i bought the bike used with 30 hours so i dont know who makes the skid plate but i will take pics and see who makes it and let you know. I think ill stick with 40:1 and be plenty safe after i adjust my lectron correctly ...
  4. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    What mixture did the previous owner run? I make it a point to ask what mixture/oils were being run in a used bike before making too many changes.
  5. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    The dealer I got it from had no idea thats why I'm worried about all of this. by the way I run klotz supertechniplate in my two strokes ( idk if that's how it's spelled)
    justintendo likes this.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    The engine will definitely last longer at 32:1, but it must be jetted to do so. Many riders down here use 36:1.
  7. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    hmmm you have a good point
  8. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Ty and I argue about this all the time. He runs 40-50:1, however, he has already had to fully rebuild both of his 2015 250 and 350's this year.
  9. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    wow that a little excesive, i guess i cant go wrong to run 32:1 if im already going to mess with the carb
  10. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i also run super techniplate klotz, have forever. have also run 40:1 forever. i get good engine life out of stuff, but i dont race, just play ride but i dont take it all that easy on stuff. do you race? if i raced all season i would likely run 32:1...
    dont forget ty davis is a mega fast racer.
    on the other end of the spectrum i have a 88 xc250 that still has 215 psi compression that i bought as NOS. it has over 200 hours on the original bore. all its life has been 40:1, mostly klotz super tecniplate. before that golden spectro before i discovered castor.
    if you have huge amounts of spooge, it likely isnt the premix, as the klotz i run has a very very high flashpoint of 460f, and i have little spooge issues, long as the exhaust isnt leaking. very little smoke, none once warm
    24valvecummins likes this.
  11. justintendo klotz super techniplate junkie
    good luck and ask around here if you need help with the lectron. they are great, love mine!
  12. Motosportz CH Sponsor
    that skid plate is uptite.
  13. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    you made me change my mind. Im like you , I don't race but I'm not easy on it. I have 40:1 in here now so I'll stick with it. I'll tune my lectron tommrow tommrow since the idle screw is only a half turn out.
  14. husky jim Husqvarna
    USA
    Thanks, It looks just like the one he made for the left kickers in the late 80's
  15. justintendo klotz super techniplate junkie
    hmm, half turn out from fully seated sounds like its rich, just guessing..
    may the power of the castor be with you
  16. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    Petar likes this.
  17. ajaxauto Husqvarna
    I have always run some where between 32 to 35 to 1 BUT with straight 110 leaded race gas I have a 2006 Cr 125 that has more race miles then I believe any other 125 out there and it is still on the same stock cylinder and only 1 crank bearing and rod kit since 2006.
    My current 2010 Husky 300 race bike went 4 years on the stock crank and is also on the same original cylinder
    With race gas and the stock carb it does not spooge ever no matter where I ride it
    Tinken and justintendo like this.
  18. justintendo klotz super techniplate junkie
    spooge is jetting and engine condition more than anything, i believe
  19. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    I mix what the owner manual says, 2% synthetic (that is 50:1) and used 3% (32:1) for the brake-in period.
    Most of the guys I ride with that have 2 strokes are using far less oil than me, some 1,5% (65:1), others even 1% (100:1), the guys that runs 1% are competing in the local and national enduros and they don't have problems as it seems...
    I do like going that lean with the oil and prefer to stick with 2%. But my bike is smoking a lot and sometimes I'm thinking of lowering the premix a bit.
    The problem is that we do some slow enduro over here, I rarely get over 1/3 throttle and the engine gets loaded up with oil and starts to smoke... I some open sections I do twist the throttle and the smoking get better after a few accelerations.
    Well, thinking it, I think I'll let it as it is and continue smoking up the guys that goes behind me hehe
    Regards.
  20. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    My mind is pretty much made up now, ill stay 40:1. Ill tune my lectron today since we finally have some nice weather here in jersey. Thanks for the input everyone it was much appreciated :cheers:
