Another Speedo Button Fix
Discussion in 'TR650' started by mag00, Sep 16, 2017.
  1. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    I pulled the speedo apart to make the "paperclip" mod to my button. When I got it apart, the previous owner must have tried to fix it and the "push rod" that breaks was missing.
    Scrap that mod, come up with new mod I had been contemplating. Works like a champ. May try and draw it up for a 3d printer, or if somebody else with better drawing skills want to, here is the idea. 2 peices, drop in, no glue or fabrication. These are very crude prototypes :eek:
    Here is the fitment. This is held in place by the white plastic it fits into and the outside of the speedo housing once assembled. The pin is just made out of a golf tee, and the plastic part used to have copper wire wound around it. I am looking for other items that would work, but I think a 3d printed part would be more precision and look better. I originally was going to glue it, but it seems to stay in place just nice. The T is light, and the switch button is plenty strong to operate it.
    More food for thought for those tempted to fix the selector button.
    Martinehijo, nev.., William42 and 2 others like this.
  2. nwrider1 Husqvarna
    SW Washington
    Too many to list
    Interesting fix. If mine ever fails I'll have another option to look at for repair!
  3. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Thanks to danketchpel's mad cad/3d modeling skills, it's almost done. Going to see if I can print up the first ones and see how they fit.
    sussurf, nev.., PaulC and 2 others like this.
  4. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    First fitment, needed some filing to make fit.
    Mark_H and nev.. like this.
  5. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    What are you going to do with the pushrod? It was previous discussed that a solution which rests on the button on the circuit board might cause premature failure of the actual button. I was thinking maybe a couple of mm of foam to keep the pushrod from always sitting on the pin, or a small spring that would hold the pushrod 1mm off the button until it was pressed ?
  6. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    The concern is good, and was addressed and examined the very first time I tried it.
    The micro switch has a very stout spring in it. The pin weighs nearly nothing.
    If a person wanted to, the pusher rod could be made with a shoulder for a small plastic spring. Metal might cause issue, but a plastic laminate/layer/washer on the switch (cut hole for button) could be a solution. Finding the right diameter "Click Pen" spring would be fun.
    I think depressing the button is going to cause more wear than the pin floating on the switch.
    The switch itself is not a switch per se, but rather a contact that pulses the dash through function.
    https://www.sparkfun.com/products/97
    http://tymkrs.tumblr.com/post/19734219441/the-four-pin-switch-hooking-it-up
    The rubber button that you push preloads the pin, so rattling does not happen. If you add another spring or cushion it is redundant as it is all built right into the switch. Even with the preload, the button has distinct click that will not activate with bouncing. The original design preloads the switch worse than the "floating" pin. Lifting the pin will interfere with the "travel" of the pin, which is already limited some by the rubber button on top. In my first try, I can toggle using gloves. I haven't buttoned this one up yet, getting more accurate dimensions for the finished product.
    Adding more pressure could cause issue with the circuit board the switch is mounted on.
    I would not recommend any other parts to this solution, it is being designed to just drop in and work. Trying to keep parts as light as possible (and non conductive), using ABS so that the heat won't warp or melt it.
    nev.. and Mark_H like this.
  7. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    This is how they ended up. Got an order in to the 3d printer. (pin not installed)
  8. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    Moto Guzzi, Ducati, Beta
    The fit came out pretty good in the end.
  9. turtlemoye Husqvarna
    Greensboro, NC
    2013 TE511, TR650 Terra
    2016 BMW 1200GSA
    Any chance I could get one of those from you or have you possibly share the file you used to print it?
    Matt Crawley likes this.
  10. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Man, I totally forgot about this project. The button works perfectly on both my bikes and my friends. I had a few made up, so yeah, I'll PM ya. Do you need the small torx for speedo disassembly?
    Adsun likes this.
  11. duibhceK Husqvarna
    Chapel of the Well, Belgium
    TRX850; WR450F; XT660Z Tenere
    Would love to have the file as well. Any chance of an STL or other 3D format file? I'd like to print a few on my own printer as well.
  12. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    mee tooo!
  13. Matt Crawley Husqvarna
    SLC, Utah
    2013 TR650 Terra
  14. ecn226 Husqvarna
    Beachmere QLD
    CRF250r CRF150R
  15. LED Husqvarna
    Perth, WA
    TR 650 Terra
    SIX
  16. Chuffa Husqvarna
    Perth, West Australia
    TR650
    XT250
  17. NYCMX Husqvarna
    Spring Hill Florida
    13 TE310R,13 Strada,
    1977 Rm125,78 Rm125, 80 RM125...KTM
    Eight....4 sale?
  18. Nick780 Husqvarna
    83 Suzuki GS400E
    Nine, if available.
  19. Martinehijo Husqvarna
    Mexico
    TR 650 Strada 2013
  20. Baddrapp Husqvarna
    Yucca Valley
    TR650
    I would like one also.
