Any advice for painting Acerbis 5.5 gallon tank
Discussion in '4 Stroke' started by JCH4, Oct 11, 2009.
  1. JCH4 Husqvarna
    South Carolina
    Any advice for painting the Acerbis 5.5 oversize tank that fit the 92-99 Husqvarna 350 or 410. Would like to do it correct the first time. Advice, comments, suggestions, thoughts, etc appreciated.
  2. JCH4 Husqvarna
    South Carolina
    This is what it looks like at the moment.
  3. terryth Husqvarna
    Nebraska
    Personally, I don't think it can be done with anything that would stay on or stay looking good for any length of time at all unless its new and you never put gas in the tank. I never tried it but its hard even trying to keep graphics stickers on my IMS on my DRZ400. The plastic is like a little permeable to something in the gas. The stickers bubble and don't stay stuck for long at all.
  4. Motosportz CH Sponsor
    Looks like it has been painted before. I used to paint cars for a living in a former life. You will need to prep it well and remove all the old paint. Scuff it real well. Make sure you use flex additive (as used for modern urethane car bumpers) and ask the paint sales guy what type of paint might last the longest. As noted above it will be interesting to see how long it holds up. there are a lot of great epoxy primers that adhear like a mad man to almost anything, might be a good idea here.
    Are you looking for nice shinny street bike look? If not cover that thing in graphics (stickers) and go ride.
  5. Joe Chod Husqvarna
    upstate NY
    use awlgrip or Imron paint. It is a polyurethane,flexy and strong stuff. Boats....buses, other comercial fleet applicatins.
    Joe
  6. JCH4 Husqvarna
    South Carolina
    My understanding is there are two types of plastic tanks (those that "breath" and those that do not breath and are conducive to paint). My tank is supposed to be non-breathing and hold paint, however, I have never painted plastic. Plenty of boat hulls and aluminum but not plastic. Want to try and get it right the first time.
  7. JCH4 Husqvarna
    South Carolina
    Tank arrived and before I can even start to paint it need to remove old paint. Motosportz and anyone else, what would you reccommend to remove old paint? would prefer not to sand and harm tank underneath but do not want to hurt tank with chemical either. Any suggestions?
  8. Motosportz CH Sponsor
    Try the standard "aircraft paint stripper" they sell in auto paint stores on a little portion under the tank or something. I don't think it will effect the plastic. They make some for use on fiberglass like corvettes that might be milder.
  9. wersmokin Husqvarna
    Houston, TX
    1994 WR 350 (sold)1998 TE410 (sold)
    Hello,
    I have 2 tanks identical to yours. Both of them yellow with Krylon paint for plastic. They are both yellow and have been like that for 4 years. No scratched or flaking. I will post pics to show you sometime soon.
    Colin
  10. JCH4 Husqvarna
    South Carolina
    Thank you Wersmokin, What did you use to strip and prep prior to painting? Photos would be much appreciated.
  11. wersmokin Husqvarna
    Houston, TX
    I will have to take a look. I just found out that when my dad bought both tanks one was already painted yellow! The other one was the white plastic. I will get you more info this week and post pics as well.
  12. JCH4 Husqvarna
    South Carolina
    Thank you.
  13. wersmokin Husqvarna
    Houston, TX
    Well I have the pics but I am not sure how to post them. Talked with a friend in my motorcycle club. He told me that my dad had taken one the tanks to Polydyne to get coated. That was 5 years ago. So far the paint has held up. Like I said I have the pics but I have to figure out how to post them. I don't have them on a URL
    Motosportz post might have the right idea. Using an epoxy primer. I used those when I was coating aircraft components. Not cheap but it's almost bulletproof. It's so durable. That might be what used on my gas tanks.
  14. Up-tite Husqvarna
    These tanks are NYLON not plastic so they DO NOT permeiate the fuel vapor thru them. Many were painted from the factory. Thoes that were had a black primer on them first. First would try some stripper on the botton inside tunnel only, to test it. Also just paint a small area only just to make sure. Later George
  15. JCH4 Husqvarna
    South Carolina
    Update in regards to my progress on this for those who may encounter same issue. After trying sanding (not the best if you want to be able to see fuel level through tank), citrus stripper (worthless unless you want to smell like an orange) and aircraft stripper, the aircraft stripper is the way to go. Make sure you go to a marine store and get the "Klean Aircraft Stripper for FIBERGLASS". The Aircraft Stripper sold in a auto parts store looks exactly the same except for the term Fiberglass and is NOT to be used on synthetic material.
    The best luck I have had so far is taking the Fiberglass Stripper and letting it sit for ten minutes and then taking a straight edge razor blade and scrapping off layers of paint. Be patient and try not to guage the nylon tank with the blade. At this point I have done one side and there "appear to be no ill effects 24 hours later", however, I pressure washed off any residue to help ensure no damage. Will try and post finished product when I get to that point.
  16. wersmokin Husqvarna
    Houston, TX
    Let me know how it goes! Can't wait to see the finished product. Any luck on a gas tank bracket?
    Just purchased the Roc Stompa footpegs for my 2000 Husky. So looking forward to using them. Those things are huge!
  17. JCH4 Husqvarna
    South Carolina
    After two solid days of stripping I only have "most" of the two sides. I believe I am going to leave it clear on one of the two vertical strips of masking tape so I can see fuel level and paint the rest white. You can see it on the bike in the photos.
  18. Vegas Husky Husqvarna
    Las Vegas Nevada
    Looks good..is that a 109 or 110 in the background??
  19. mxracernumber1 Husqvarna
    I could be wrong, but I'm betting that the tank is PP or LDPE like every other plastic part on a dirtbike. LDPE is more commonly used in blow-molding applications which is how tanks are made. Also, Nylon is way more expensive. At any rate, enough about that-if youu have access to a good glass-bead booth (sandblasting booth), that would be the easiest and best bet. In fact, it would be so much easier that it would be worth searching for one locally and maybe even paying to have it done. I could strip that whole tank in about 15 minutes and even knock off the top UV-damaged layer of plastic. It would still be tanslucent and look pretty well like new as plastics are unaffected by this process, unless you hold the gun right up to it for an extended period of time and try to melt it. Since this tank probably had somewhat of a vapor-honed finish on it when new anyway, sanblasting won't change it from original that much. This tank is no doubt a candidate for a glass-beading. You also won't have those nasty scratches like ou get with sanding. Just clean thoroughly afterwards.
    By the way, be careful which solvents you apply to any plastic. Some may not have immediate affects, but will cause the material to weaken and/or discolor in the long run.
    As for the paint, this is one of the eternal questions on any website that covers dirtbikes. It seems to never go away, like a stray dog. There are some high-tech paints out there, but still even car bumpers don't get hit like dirtbike tanks do. Gonna be tough getting it to stay pretty. Take lots of pics.
  20. JCH4 Husqvarna
    South Carolina
    A 109 (1972)
    I may try and track down a bead blaster
