250-500cc Any good aftermarket clutch perch and lever to fit huskys
Discussion in '2 Stroke' started by dan s, Jan 17, 2013.
  1. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    I was wondering if anyone has any good experiences with a good aftermarket clutch perch setup on the wr 250's or 300's? Nobody list them for the wr's that I can see. I'm sure one could work that's made for another brand possibly. Thanks
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    just curious as to you don't like the stock one?
    it's a Domino, I tried others and have to say these are a good choice
  3. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    +1 for the domi's. man it's nice to have a star flicker at the end of a clutch smokin' 15 min. climb!
  4. 2premo Husqvarna
    Northern NV
    if you're liiking for something different they make a hydraulic kit
    heard they are nice
  5. pvduke Husqvarna
    ... on the gas...
    Motosportz Frankenbike set up!!!
  6. burstcasino Husqvarna
    Austin, TX
    2012 Husqvarna WR300
    2001 KTM 520 exc
    Anybody know if Tusk or Motion Pro make a wr300 clutch lever? I've seen clutch levers for the TE250. Are these TE levers compatible for a 2012 wr300. Can't find a wr300 clutch lever anywhere.
  7. burstcasino Husqvarna
    Austin, TX
    2001 KTM 520 exc
    Looks like the TE has a juice clutch.
  8. pvduke Husqvarna
    ... on the gas...
    motion pro
    ebay
    tusk
    concept distributing
    google it there's tons of them...
    back in the day we'd swap em all out for Honda CR perches and levers...
  9. pvduke Husqvarna
    ... on the gas...
  10. kx3089 Husqvarna
    western pa
    wr250
    I use a msr lever and perch,has a nice star adjuster
  11. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    ASV clutch lever/perches fit most anything I think. I took my ASV clutch off the KX250 I sold and put it on my WR, I did end up having a shorter cable made by Motion Pro for it.
  12. nonamerider Husqvarna
    Oklahoma
    stock.ihave tested most and they all have less than 26mm plus throw you need for your husky. most copy hondas specs at 25 . yamaha 24 etc. causes clutch problems.
