TE/TC any one know will the rear wheel from a 2014 Husqvarna tc 250,bolt on to a 2015 tc 250?
Discussion in '2st' started by fletchman45, Jan 9, 2015.
  1. fletchman45 Husqvarna
    park rapids
    I sure hope so .I just bought one off eBay! The 14 husky had a 20mm rear axle while the KTM had a bigger one. Not sure if the 15 changed to the larger size and if they did do I just need the spacer or????
  2. TROFFER88 Husqvarna
    Camas Wa
    I believe Enduro engineering sells a kit
  3. LandofMotards Moderator
    Colorado
    2014 TC250
    Front axle size changedbut have never read anything about the rear. Should be good to go
    fletchman45 likes this.
  4. fletchman45 Husqvarna
    park rapids
    I know front axle changed size and have never got a real answer but it is my understanding you can put and older front rim on a 15 by just changing the rim spacers. That's what I'm told at least... I just can't confirm if the rear axle size changed from 14 to 15 on the huskys. Got a new takeoff 14 rear wheel with the tire for $400 delivered. Need to research front as well...
  5. Norman Foley Husqvarna
    Rear axle on some bikes changed. KTM SX changed, so possible Husky TC changed. At the least you'll have to swap your '15 spacers into the 14 wheel to use it. At most you buy another set of spacers.
    Think of it like the difference between '00 and '01 Husky rear wheels... '00 had small axle and spacers that pressed in the bearings. '01 has same wheel and bearings, but a larger axle that was the same OD as the bearings' ID and the spacer just fit in the seal. Different diameter axle and the same wheel....
  6. Norman Foley Husqvarna
    From a KTM Talk wheel fitment thread.... This should apply to 14-'15 Huskys too.
    "In 13 the rear axle got bigger on the sx and xc. In 15 the front axle got smaller on the sx and xc. Regardless, all you have to do is swap the spacers and any ktm wheel will fit on any bike from 04-15."
  7. LandofMotards Moderator
    Colorado
    2014 TC250
    In 2014 atleast the front axle was different. I'll have to search for the magazine but they questioned the difference with the two bikes. Like you said, just need spacers so not a big deal.
  8. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    Both the 14 and 15 TC250's have a 20mm axle. The wheel and spacers will interchange between both bikes.
  9. fletchman45 Husqvarna
    park rapids
    Thanks much. This to me means just buy a set of spacers and throw in the wheel I bought and bingo a guy can do a five minute tire switch. Should be able to put spacers in and older front wheel on a newer bike
