Any tips for making a mx track?
Discussion in 'General (Main)' started by WHITEROCKET5.9, Apr 29, 2011.
  1. WHITEROCKET5.9 Husqvarna
    central illinois
    going to start making a track in the field we have and was wondering if any of you guys have any experiance makin them. particularly in the size the jumps need to be(like the base of the dirt needs to be 15ft wide by 20ft) ect how wide the tracks usually are, how far apart certain things need to be to keep from killing myself ect lol or if thers a track creating website. thanks in advance
  2. WHITEROCKET5.9 Husqvarna
    central illinois
    started the track the other day, unfortunately blew a seal on the bobcat a hour into it but its fixed today so ill resume soon. alot of sand where im at which could be good and bad i guess. ill post some pics up as i go
  3. HuskyT Moderator
    Corona, California
    Loaded question but for safety the wider the better...25 ft wide min up to 50....depending on the experience of the rider you can go from all the way down beginner to SX... if your the cook you add the ingredients...
    I would start with basic tables 20 to 35 ft and then add some singles...ride it for a while with your whole crew.... after that start adding some step ups and step downs and longer tables 40 to 50 ft and some laid down doubles.. then progress to some bigger and higher gap doubles and a longer table... say 75 ft.... add a rhtym section and a whoop section whenever you feel its right!
    JMO
    T
  4. WHITEROCKET5.9 Husqvarna
    central illinois
    thanks! all opinions are appreciated on this.
