anybody drop a tooth on the front sprocket 08/09 te250
Discussion in '4 Stroke' started by hipsterdufus, Aug 29, 2009.
  1. hipsterdufus Husqvarna
    KS
    just wondering how it felt in the tight stuff? thinking about dropping to a 12t to move the powerband a little lower. never going to ride this on the street
    hip
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    12T in the front would serve better in the tight stuff.
    A lot of riders go 2T larger in the back.
    A little easier on the chain, but a little harder on the wallet.
    I run 13-49 on my 510.
    :cheers:
  3. hipsterdufus Husqvarna
    KS
    i hear dropping 1 on the front is like adding 3 on the rear
    husky parts book goes up to 50t but supersprox.com is listing a 52 :applause:
  4. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    I thought my TE 250 was pretty nice stock 13/50. It pulled so smooth off the bottom. Changed it to a 14 as I'm mostly riding desert stuff and it's fine there.
    12/50 would be fun for real low speed stuff certainly. Don't know that I've seen anyone do it.
  5. hamiltonuh60 Husqvarna
    I'm currently running 13/52 on my 08 TE250. I do ride it on the streets but my speeds are no greater than about 35 mph. Acceleration is great but really hampers top speed and you shift through all six gears rather quickly.
  6. I8AKTM Husqvarna
    I race enduros and hare scrambles. Fairly tight here.
    I run 12-50 on my TXC250 and love it.....but I rarely ever get to 4th or 5th gear.
  7. I8AKTM Husqvarna
  8. ScottyR Husqvarna
    Mitchell, ON
    I put a 12T on mine a few years ago and didnt like it. It seemed like I was doing a tap dance on my shifter when riding it.
    I like 13/51 on a 250. It doesnt make a huge difference but does help with the roll-on power a bit.
    I just put 13/51 on my 310 and I am not sure that I like it or not. I think I am going to go back to a 50T and compare again.
  9. TrailPunter Husqvarna
    Escondido, CA
    Mine's an 06' and I've used a 12t. In the really tight nasty stuff it's great. As soon as it opens up you run out of gears real quick. I'd love it if first was that low with the stock 13/50. Then you would have a creeper/granny get off and run alongside gear and nice spread from 2nd through 6th.
    Later,
    Mike
  10. hipsterdufus Husqvarna
    KS
    im thinking just raise the rear sprocket 1 or 2 teeth just to get that extra oomph down low. right now it takes to long to climb in 2nd and 3rd. you have to wait for the power to climb
    we shall see, ill order tonight
  11. hipsterdufus Husqvarna
    KS
    ordered 51t rear from motorsportz to test out
  12. 420skirider Husqvarna
    Phila, Pa
    I ran a 52T on the rear of my TE 250 and it helped the low end in the tight stuff. I try to stay away from the 12T front sprockets because it kills the chain and it almost eliminates 1st gear.
    BTW, switching to a 12T front from a 13-50 stock combo is the equivalent of adding 4 teeth on the rear sprocket. (50/13=3.84 ratio[stock] 50/12=4.16ratio 54/13=4.15ratio).
  13. hipsterdufus Husqvarna
    KS
    it acutally ended up being a 52, motorsportz isnt stocking the 51 anymore and i just installed it tonight and ripped around the dirt road a little, feels much better
    sunday it will get a full flogging :cheers:, thanks for the help everyone!
  14. TE250Guy Husqvarna
    Washington
    2008 TE250, 2013 TR650 Terra
    2009 KLR 650, Yamaha XT 225
    Were you able to use the stock chain with the 13-52 combo?
  15. gandalf Husqvarna
    South Jersey
    Should be no problem.
  16. hipsterdufus Husqvarna
    KS
    it worked out great with stock chain, maybe 3 threads and the locknut showing on the adjuster. about perfect
  17. snoplw Husqvarna
    Moorhead, MN
    my self I have not changed mine but I am going to go up just 1 on the rear. I have raced my 08 te 250 this year and won the AA class with the stock gearing. First gear is to tall for tight woods and makes it alot of work. I just got this bike good deal, I honestly can say I have been tryingg to get the efi to run more cleanly.
  18. 420skirider Husqvarna
    Phila, Pa
    Mine was too tight with the stock chain. It might have worked, but I didn't want the rear axle almost all the way forward on the adjusters.
  19. TE250Guy Husqvarna
    Washington
    The tire rubbed through the mud flap on my son's 09 TE510 when he moved the axle almost all the way forward on the adjusters. I think it barely clears static but the air at 70+ mph may move the flap to hit the tire, but it is hard to tell since both his flap and tire are now worn.
