250-500cc anyone know the quantity for 2010 WR300
Discussion in '2 Stroke' started by windsurf, Jun 27, 2011.
  1. windsurf Husqvarna
    queesland
    Always thought the Kayabas felt a bit on the stiff side. I have just drained the fork oil and found 600ml in each leg. I thought it was supposed to be around 320 per leg. Does anyone know for sure, our importer has just told me 720ml per leg? or 120mm from the top when leg is fully compressed. This sounds like a huge amount but without a proper manual I don't know.
  2. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    120mm from the top is for the open chamber 50mm zokes, no idea if it is the same for the KYBs
  3. QuadExpert Husqvarna
    Ottawa Canada
    1976 4 speed auto,2011 wr 150
    check with Tierie from Stadium suspension.
    tell him Mark from Quadexpert sent you.
  4. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    I thought the Kayaba's were a standard open chamber or cartridge fork? If thats the case, pay attention to the type and weight of the fork oil and play around with the airgap/fork oil level...never worried about the quantity that goes into the cartridge fork more the oil level and weight.
    BTW 90-110mm is a good range for most terrains.
    See:
    http://www.youtube.com/watch?v=Y43k1qFVGW4
    and
    http://forks.darladog.com/
  5. huskydude59 Husqvarna
    Berwick
    Dont panic, i have the same problem. The manual is junk there is a site called Dirt bike world,, get on there and hunt down settings for the yz250 2005 model.. I have set mine to 130mm fork compressed 5wt.. take you time bleeding them it makes a big difference to the level. If you are 70~80 kg std springs are fine, if you are like me 90+ go get a set of 0.48.. same oil volume. take special care to run the forks thru there stroke before you tighten the axle.. it can make the fork bind up.. start your setting at mid way on rebound and compression.
