TE/TC Anyone running Mobil1 0w-40 in the modern husky 2-strokes?
Discussion in '2st' started by Cavery, Jun 10, 2017.
  1. Cavery Husqvarna
    Toronto
    2010 TXC 250
    I've been using it for years in my 2010 Txc250 thumper with absolutely no issues. I recently picked up a MY17 TE250 which is is my first experience with a 2-Stroke. I've still got a few jugs of the Mobil1 and I thought about using it as gearcase oil in the new bike. Its time for my first oil change.
    The manual suggests 10w-40 synthetic, so I'm thinking it should be fine. Anyone else with a MY16+ using it in their smoker?
  2. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Wow I thought the 2 strokes ran a gear oil like 50w.
  3. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    I've been using it for 3 years in my 2t with no problems.
  4. not2old Husqvarna
    Scotch Creek, British Columbia, Canada
    99 360 WR, 07 510TE, 16 TE 300
    CBX, R100RT, K100RS, XL1200R
    I run ATF in my 2 stroke gear cases. Started this with my 1999 360WR to help with excessive drag. Recently sold that bike with all original clutch.
  5. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    1988 Honda Hurricane,
    I ran the Mobil one in my txc310, but on my 2015 TE250 and now in my 17 TE300 I run the BELRAY gear saver.
  6. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    20 hours on oil changes with the gear saver.
  7. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I use it in my 300 2t and 501. The 501 has 5800 miles on it now, shifts perfect and oil changes are drama free as in no mystery pieces on magnets and filters.
  8. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Maxima MTL XL 75w may test MTL Racing 80w.
  9. ripnriding Husqvarna
    Kingston, Ontario Canada
    2017 TX 300 and 2010 CR 144
    2007 husqvarna TE 450(sold)
    Have put two changes with 13 hrs on with Motul 10w30. Minute bits of metal on magnet but anticipate normal with break-in. Shifts beauty. Am tempted to go with the manufacture spec Belray next time to see if there is ANY difference..
  10. Valhalla Husqvarna
    Wisconsin
    2015 TE 300
    I like the OEM recommended Bel-Ray EXL mineral oil. Keeps the cogs happy, no issues whatsoever.
  11. ptkatoomer Husqvarna
    San Diego area
    None
    2020 ktm 300 xc-w, 2020 ktm 500exc
    I do the same with my 2 and 4. Keeps it simple in the garage and both are working fine.
  12. PaulD Husqvarna
    Little Egg Harbor N.J.
    2010 wr250( sold)
    Triumph Sprint RS. Honda TRX300EX Be
    Yes I use it in the gearbox of my WR250 shifts good no problems so far. Tried Rotella 5w-40 and it seemed to make gear changes a little notchy
  13. hakkalugi Husqvarna
    North East PA
    17' TE150
    Gear oil & engine oil have different weights that mean the same. I believe like a 70w gear oil is same as a 40w engine oil if im not mistaken. Ive been using rotella T6 5w-40 in mine every few rides no problems so far, as said above my shifting does seem a little notchy so I may try something els out once I run out. Any oil is better than no oil, just keep on routine changes & im sure you wont have a problem.
    Teambowles and huskybear like this.
  14. huskybear Husqvarna
    B.C. Canada
    I've been using rotella t-6 5-40 in all my 2 and 4 stroke bikes and ATVs for years with excellent results. It is jaso-ma rated which means it is ok for wet clutches.
    hakkalugi likes this.
  15. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Your TE250 manual says synthetic? My '17 TX300 manual says Bel-Ray EXL Mineral 4T oil. I ran that during my break-in ride (2 hours), changed it out with more of the same. Then went for a longer ride, and after about 3 hours the clutch turned into an on/off deal. So I changed over to the same stuff I use in all bikes: Rotella T6. It's in my street bike, my subaru forester and was used in my WR250, TE511, KLR650 and KLR250 when I had them. I can get way more than 10 hours out of it in the 2 stroke, but usually just change it after 2 rides. Amazon has the best price. I usually buy four 1 gallon jugs rather than the 2.5 gallon jugs, because the better pricing is on the 1 gallon. And the 1 gallon jugs are much easier to pour.
    huskybear likes this.
